Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1987 - 1996 F150 And Larger F-Series Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 07-03-2008, 02:02 PM
allwaysoffroadin is starting off with a positive reputation.
Cool 87 4.9L just shut off while driving
Yeah I have an 87 F150 with the 4.9L and its a 4 speed. But yesterday as I was driving the motor just cut out, it didn't sputter or choke or anything. I was wondering if anyone else has had this problem and knows what it is or if anyone knows if its a fuel or ignition problem. Thanks
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 07-03-2008, 02:05 PM
Kemicalburns's Avatar
Kemicalburns is gaining momentum as a positive member of FTE.Kemicalburns is gaining momentum as a positive member of FTE.
is there gas in the tank? do you have more then 1 tank ?
__________________
94 XLT 5.8/E4OD
6"ProComp Stage II 35x12.5x15 BFG MT's ,
4.88 gears f/r
installing soon: JBA shorty, Bassani Y pipe, Edelbrock efi truck intake, , aussie front/rear
88 (Rolled)
http://www.supermotors.org/registry/vehicles/detail.php?id=4158
  #3 (permalink)
Old 07-03-2008, 02:06 PM
Yes it has a full tank and I have 2 tanks and I tried flipping the switch to run off the other tanks but it still wouldnt start
  #4 (permalink)
Old 07-03-2008, 02:51 PM
is this efi or carb. check for fuel and spark
__________________
94 XLT 5.8/E4OD
4.88 gears f/r
88 (Rolled)
  #5 (permalink)
Old 07-03-2008, 03:28 PM
It is an EFI motor
  #6 (permalink)
Old 07-03-2008, 03:45 PM
85e150six4mtod has a good reputation on FTE.85e150six4mtod has a good reputation on FTE.85e150six4mtod has a good reputation on FTE.
Would he have the dreaded TFI ignition?
Have you checked for spark?
No spark & a TFI ignition is pretty much the TFI module. Were you on railroad tracks in front of a fast freight? That's usually when they fail, so maybe you got lucky.....
  #7 (permalink)
Old 07-04-2008, 12:11 AM
88n94 is starting off with a positive reputation.
I agree, you could check for spark but it's most likely the ignition module on the side of the distributor. About forty dollars at Advance Auto Parts. You need a special tool to remove and reinstall the module.
__________________
88 F=150 4X4 4.9l 5speed. 94 F-150 4X4 5.8l automatic overdrive.
  #8 (permalink)
Old 07-04-2008, 12:55 AM
That's the tfi module. Wrench $10. But check for spark first, if you have spark, go to fuel.
  #9 (permalink)
Old 07-04-2008, 01:25 AM
gweeds's Avatar
gweeds is gaining momentum as a positive member of FTE.
Wait wait before all of this... Do you have any power? If you don't, your alternator died. If it cranks though, forget what I just said...
__________________
If you need any computer help/advice, pm me.
-94 f250 XLT 4x4, 7.5L, E4OD
-86 f250 XL 4x2, 6.9L, C6
-95 Nissan Hardbody, 2.4L, 5spd <-- The real work horse!
"Greater love has no one than this, that he lay down his life for his friends" - John 15:13
  #10 (permalink)
Old 07-04-2008, 06:18 AM
cbslayer's Avatar
cbslayer is starting off with a positive reputation.
i had this same problem with 87 f150 in line six but it happened when we had some rain i was driving down freeway and it justr died so i messed with wiring some and it started then 3 days later after it rained again it died (at the worst possible spot 2 lane state route with no where to pull off )had to get it towed it took me 8 days i changed everything ignition module,distributer,fuses cap rotor wires i finnally traced it down to on driver side fender well 2 relays one brown one green i tried buying new ones from auto parts store but they couldnt match them so i went to bone yard and searched i got them for 5 bucks those 2 relays control power to fuel pumps and ingnition and injectors that may be your problem just a thought
__________________
Life is a journey not a destination (Aerosmith)
  #11 (permalink)
Old 07-04-2008, 07:13 AM
rquinlans is starting off with a positive reputation.
timing chain / gear , before you start adding a bunch of parts take it to a shop and get diagnosed , just bought one that "died" , no explosions or noise , the guy had just put about 350 bucks in parts on it , took it to my mechanic and it was what I suspected , timing gear and chain , cost $550 to get it repaired.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
