Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Super Duty And Heavy Duty
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 07-03-2008, 01:50 PM
NM_F450 is starting off with a positive reputation.
Turbo Pyo for '08
I recently bought a 2008 F450 (replacement for a totaled Excussion - more on that in a nother post ). My question is...what are my options / needs for a turbo pyromenter. I have one on my 1985 F250 and it is invaluable for the mountian towing I did with it.
Thanks,
Bill
__________________
Bill
2008 F450 King Ranch 6.4 PSD
2009 28' Sundance 5th Wheel
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 07-03-2008, 03:27 PM
Beerstalker's Avatar
Beerstalker has a very good reputation on FTE.Beerstalker has a very good reputation on FTE.Beerstalker has a very good reputation on FTE.
I have the MSD Dashhawk and I really like it. For my truck I had to buy an add on EGT probe that I drilled and tapped into the drivers side exhaust manifold. I am pretty sure that the 2008 already has EGT sensors in the exhuast for the regen process, and the Dashahwk can read them from the OBD-II port so you wouldn't even have to add anything else.
To read some more on the Dashhawk check out my thread here.
http://www.ford-trucks.com/forums/58...e-display.html
I also suggest you scroll down a little bit more on the main forum page and check out the 6.4L forum. There will be a lot of information on your truck/motor in there.
__________________
2007 F350 Lariat, CC, LB, 4x4
4.5" DR Lift w/35x12.5r20 Toyo Open Country M/Ts
Keystone Restyling Ram Air Hood W/Airaid Intake & Pre-filter
Recon Smoked Cab, Mirror, and Brake Lights
MSD Dashhawk w/A Pillar Mount
Dieselsite Coolant Filter
Lund Eclipse Window Vents
Weatherguard Toolbox
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
