Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
LinkBack Thread Tools
  #16 (permalink)
Old 07-03-2008, 02:48 PM
miller_feed's Avatar
Hook it, I'll pull it.
miller_feed is a splendid one to beholdmiller_feed is a splendid one to beholdmiller_feed is a splendid one to beholdmiller_feed is a splendid one to beholdmiller_feed is a splendid one to beholdmiller_feed is a splendid one to beholdmiller_feed is a splendid one to behold
Quote:
Originally Posted by zx250 View Post
Yep, that's right, but at the rate he was pumping it out and while the truck was under power, I don't see how the fuel would get through the engine and exhaust cold enough to stay white.
Barry, I think that as he was pressing the go pedal, the PCM sending signal to pump more fuel, but not getting enough air to burn all the fuel.
__________________
RICK, PAA MEMBER #4
2001, F-350, DRW. CC. LWB, 4X4, LARIAT,
MODS: 6637 W/Pete's filter cover, BTS-VB, DP-TUNER- stock, 40t, 60t, 80e, 140s, HI, OBA, 203*, billet housing, IH bolts, MBRP 4" SS, Isspro 3 gauge kit, Zoodad, Foil delete, TN-BB turbo, Bellowed up pipes, HPX, TRU-COOL cooler. For now.
Jim, Roland, Will, JD? I want to go somewhere.
Sponsored Links
To remove this ad, register today!
  #17 (permalink)
Old 07-03-2008, 02:53 PM
zx250's Avatar
Spread the wealth my ass!
zx250 is a name known to allzx250 is a name known to allzx250 is a name known to allzx250 is a name known to allzx250 is a name known to allzx250 is a name known to all
Ok, but I still think that's a lot of smoke just to be that, and there is the the fuel in the oil issue.
  #18 (permalink)
Old 07-03-2008, 02:56 PM
Smokin''s Avatar
Smokin' has a great reputation on FTE.Smokin' has a great reputation on FTE.Smokin' has a great reputation on FTE.Smokin' has a great reputation on FTE.Smokin' has a great reputation on FTE.Smokin' has a great reputation on FTE.
Lets also not forget that the truck will barely idle, or even move at all, and stalls in reverse. & like barry said, fuel in oil and the mysterious green fluid.
__________________
Lisa
Early '99 long bed XLT supercab. 4" Pro Comp suspension lift, 35" BFG AT's, Hypermax Boost Pyrometer, 4" turbo back exhaust setup, Hypermax 330 chip.
Quote:
Originally Posted by 87 F-150 I6 View Post
Whenever I see a prius drive by I always hear a very fant "I'm gay", its so weird
  #19 (permalink)
Old 07-03-2008, 03:00 PM
Not saying he does not have other issues. Also, I have never had a boot blow off, so I am just speculating.
__________________
RICK, PAA MEMBER #4
  #20 (permalink)
Old 07-03-2008, 03:01 PM
zx250's Avatar
Just curious if the bang was problem or if the problems caused the bang. He said he had a 1211 code, that's HPOP code and that could be the problem with Idle. Without fresh oil, and I would recommend pulling the oil out of the HPOP and replace it as well, we are just guessing. As far as we know, someone prior to him, may have put fuel in the oil fill for some reason. I still want to know more about what the BANG sounded like.
  #21 (permalink)
Old 07-03-2008, 03:04 PM
Yes, we have another BIG BANG THEORY here.
Maybe he ran into the back of the garage because he was drunk. jk
__________________
RICK, PAA MEMBER #4
  #22 (permalink)
Old 07-03-2008, 03:07 PM
just another truck's Avatar
at least momma loves me
just another truck has a very good reputation on FTE.just another truck has a very good reputation on FTE.just another truck has a very good reputation on FTE.
if it sat for that long, could be a stuck exhaust valve.........
__________________
Pat
PAA 67
1999 F-250 LB,CC,4x4
Quote:
Originally Posted by NewEnglandHerdsman
If you listen long enough, even an idiot will say something that makes sense...
‘A democracy will continue to exist up until the time that voters discover they can vote themselves generous gifts from the public treasury.’
  #23 (permalink)
Old 07-03-2008, 03:13 PM
zx250's Avatar
We need more imput from him before we can do much more.
  #24 (permalink)
Old 07-03-2008, 03:14 PM
I agree.......
__________________
RICK, PAA MEMBER #4
  #25 (permalink)
Old 07-03-2008, 04:21 PM
schlepprock379's Avatar
schlepprock379 is starting off with a positive reputation.
Ya know...This is why I love this site and all the people involved.....A guy that MOST dont know can post a problem and get lots of people trying to search their own knowledge banks and help him, thats just great... ya know?
Well...Ok,Ive went on enough...but thanks for all the help with my AND everyones problems.Just thought Id give some thanks.
Schlepprock
__________________
Phil '99.5 F-250 SuperDuty 4x4 CrewCab/7.3 PowerStroke Magnaflow4"TurboBack Exhaust 5"Tip DP-Tuner:Stock,High Idle,Lope Idle,60Tow, 80Econo,120Race OverBoost Annihilator AutoMeter UltraLite Series Gauges Boost/Trans/Pyro BTS ValveBody Spicer Driveline ATS housing Wicked Wheel HPX Crossover DIY Tymar AIH Delete Bellowed Up Pipes PAA Member # 34
  #26 (permalink)
Old 07-03-2008, 04:30 PM
ccg711 is starting off with a positive reputation.
No thump, Bang, big bang, like an incorrect detonation. Thought the engine failed catastrophicaly internally. I went and replaced all the injector o-rings, and one had blown (1.5 years ago, with a section gone) which helped but there is still a problem. the oil was changed ofter the o-rings because it was WAY too full, and that's the same oil that has been in there which is now fuel saturated again, but not that much. plus I've run the fuel out, so I don't know how strong of a dye leak detectors are, but i've never put them in and the color was kinda bright. I'm debating how bright compared to antifreeze color.
__________________
99 f350 7.3psd auto cc lb, kwik wix, pre-pump coming soon to a theatre near you.
http://blog.technicalmercenary.com
  #27 (permalink)
Old 07-03-2008, 04:35 PM
zx250's Avatar
The green dye is faily bright and almost has a glow to in. Antifreeze will also be green but the water would cause the oil to be creamy or foamy looking. Was your reverse problem there before the bang?
  #28 (permalink)
Old 07-03-2008, 04:38 PM
btw i use to post a little bit until i found out my title was in limbo, took 1.5 years to straighten that out, i've left the truck alone till i was sure it was mine to spend money on.
__________________
  #29 (permalink)
Old 07-03-2008, 04:41 PM
truck started loosing power intermittently before the Bang, not sure if the reverse symptom was there specifically. and the oil wasn't clumpy but didn't look thick like oil, like like water or fuel. isn't ULSD greenish out the pump?
might do a search for my posts to see some history, i don't know how long the sight archives the threads, but they should have started 1.5-2 years back.
__________________
  #30 (permalink)
Old 07-03-2008, 04:45 PM
zx250's Avatar
Fuel will thin oil, Water will really muck it up, make it look like creamy coffee or something close. Fuel shouldn't be green enough that you can tell. I will look back and see if anything else comes to mind. I will post the link for others to review as well.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
