Go Back   Ford Truck Enthusiasts Forums > Misc. > Offroad and 4x4
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Offroad and 4x4 SPONSORED BY:
Is F-150 Still King?
LinkBack Thread Tools
  #16 (permalink)
Old 07-03-2008, 11:42 PM
kjett's Avatar
kjett has a great reputation on FTE.kjett has a great reputation on FTE.kjett has a great reputation on FTE.kjett has a great reputation on FTE.kjett has a great reputation on FTE.
Getting the whole motor assembled by Carl is definitely a step in the right direction. You can also talk with Lem and Charlie Evans over at BF Evans Ford Race Parts . Go to the "Our Customers" page about 1/2 way down and you'll see a certain 88 Ford ranger that used to be running around (sad days....). Your c6 is more than able to handle that motor, but there are some things to do to it to make it truely bulletproof. Get in contact with Frank Merkl out of Alberta, he knows the c6 inside and out. You can build it up yourself with a little patience and the right tools. Read through this link for things to look for:
460ford.com :: View topic - C-6 Transmission I.D. and rebuild questions.(maybe sticky?)
Same goes for your valve body, either talk with Frank as he make a killer manual valve body, with or without a transbrake if you want to race it. For you stall converter, talk with Scott Johnson out in Tacoma Washington as he can get one made up for your motor.
Axles, with a built big block and really anything over 35's, and even with chromo shafts, unless you are using that truck for straight line mud drags, the 44 and 9" won't hold up too long. If it's not a full on mud race only truck, do yourself a favor now and just find a 60kp front and either a D70 or 10.25 rear. Put the money in them and you will be much happier in the long run.
Look at me, I'm actually admitting that the d44 and 9" won't hold up to high horsepower and big tires in the long run........ Kris, I think you are rubbing off on me........
__________________
Karl
I'm the Voice of Reason
FTE - Where signatures get edited with no explination why.
95 F-150
1995 F-150
Ranger build: Ranger Mud Truck
Sponsored Links
To remove this ad, register today!
  #17 (permalink)
Old 07-03-2008, 11:44 PM
countryboy116's Avatar
countryboy116 has a very good reputation on FTE.countryboy116 has a very good reputation on FTE.countryboy116 has a very good reputation on FTE.
seems like his prices are decent too, if you do decide to get a crate sounds like hes the way to go, as for the axles, with that much power and 35s you may be pushing it, usually itd be ok but thats a pretty powerful motor, if youd rather just chromo the d44 then do that but itd personally say get a D60 to throw up front, then either a D70 or sterling for the rear, and why are you only plannin on running 35s? you could just get a small lift, break out the sawzall and run 38s, then of course youd definatly wanna upgrade to a D60, if you gunna do it might as well built it right the first time
EDIT: well ok then Karl got to it before me but you get the idea, get the D60
__________________
-Mike
HE WHO'S NAME SHALL NOT BE SPOKEN MINIONS-Rebel Peon
'97 F150 4x4 DD for now
-2.5 tons in the future
...Just a Good Ole Boy
IN TOO DEEP Offroad Club!
  #18 (permalink)
Old 07-03-2008, 11:47 PM
monsterbaby's Avatar
monsterbaby has a spectacular reputation.monsterbaby has a spectacular reputation.monsterbaby has a spectacular reputation.monsterbaby has a spectacular reputation.monsterbaby has a spectacular reputation.monsterbaby has a spectacular reputation.monsterbaby has a spectacular reputation.monsterbaby has a spectacular reputation.monsterbaby has a spectacular reputation.monsterbaby has a spectacular reputation.monsterbaby has a spectacular reputation.
actually for a TC don't call a head porter just call a torque convertor builder that knows something (scott is just a middle man on those, he just calls the TC builder with the info you give him and then sells you the product, I like scott but call the right person for the right job) Personally after using several differnt ones I ended up using Edge, they have a couple tech guys and one of them is an ex mud drag/bogger that knows how to set one up for use offroad with your engine.
And yes even I will admit that in anything other then straight line mud drags a D44/9" isn't the best setup, but IF and I mean ONLY IF your doing straight line a D44 WILL handle plenty of power.
__________________
Dying's not so bad
It's living that will kill you off
  #19 (permalink)
Old 07-04-2008, 12:04 AM
kjett's Avatar
Rob,
True, I was just think Scott because his prices are decent and he's a straight forward, stand up guy that won't steer you wrong if he can help it. But you are right about calling the right person for the job. There are so many converters floating around out there, and you hear good and bad about each of them, it's hard to find the best one for the right application. Which is why I thought about Scott as he knows the BBF motor and can give recommendations on the right stall he'll need for the motor setup. A few of the converter guys I talked with before I bought mine just wanted to sell me a standard off the shelf "custom built" converter built for the strip and didn't understand about my torque needs in mud. Scott spent a little time with me on the phone to get me in the right direction for my purposes, good guy to work with.
__________________
Karl
95 F-150
1995 F-150
  #20 (permalink)
Old 07-04-2008, 12:34 AM
STGFordCrazy04's Avatar
Dropped on Request
STGFordCrazy04 is a splendid one to beholdSTGFordCrazy04 is a splendid one to beholdSTGFordCrazy04 is a splendid one to beholdSTGFordCrazy04 is a splendid one to beholdSTGFordCrazy04 is a splendid one to beholdSTGFordCrazy04 is a splendid one to behold
Dont buy an "off the shelf" engine from Carl if thats not what you want. Give him a call and tell him what you want to doi and what youve got to spend. He can build nasty stuff for the right amount of money.
At the moment Im glad I backed out of a 545 deal. 6 months from now maybe I wont.
Kris = drunk
__________________
Kris
Quote:
Originally Posted by thorseshoeing
Yes you are the anti christ...
  #21 (permalink)
Old 07-04-2008, 12:36 AM
Dropped on Request
Scott is the man. Im glad I got in touch with him.
__________________
Kris
  #22 (permalink)
Old 07-07-2008, 10:38 AM
uncle.stosh's Avatar
uncle.stosh is gaining momentum as a positive member of FTE.uncle.stosh is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by ibleedblue1385 View Post
Where did you get your stroker kit from?
I didn't buy it in kit form.
I have a SCAT crank and everything else was bought from some people that I know that are WD for a lot of big companies like JE, Eagle, Ford Motorsports, etc....
It's nice to have friends!
__________________
I live in the salvage yard.
Pennsylvania Chapter Member
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
