Anyone here good with brakes???
ive been having this brake problem for about 2 months now. ive replaced the master cyl. twice, the p- valve, some of the hard lines and the rear rubber brake line. but the rear drums keep hanging up. I think the rear pads have worn down to where it dosnt hang up as much, but i can still sit at a red light with out holding the brakes. I still have to make sure the rear pads are on right, but is there anything else it could be?
Have your assistant mechanic apply the p brake and watch to see if the cable releases at both the adjustment Y and the drums. You may have to do this a few times to see all the points. Also something else to check would be the self adjusters.If they are difficult to turn with the adjusting finger pried away from it , it could need to be freed up. When you adjusted the p brake , did you adjust it to where it catches about half way... or does it catch at the top? It should catch or stop at about half way to the bottom.
I always make it a point when I do drum brakes to tear down the self adjusters and clean them really well. When they go back together, I use lithium grease on the barrels and threads, then check to make sure they turn well.
All rubbing points need cleaning and lube too - the ones on the backing plate and where the ends of the shoes rub on the adjusters and anchor slots.
Last step when everything is assembled is a brake adjustment. Turn them all the way tight so the tire won't turn either way, then back off the adjuster until you barely hear them touch and don't drag with the tire being turned by hand.
If all this was done - the E-Brake is about all it can be.
danlee
08-13-2004 06:15 PM
