Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1973 - 1979 F-100 And Larger F-Series Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
1973 - 1979 F-100 And Larger F-Series Trucks Discuss the Dentsides Ford Truck
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 07-03-2008, 11:02 AM
mopakel is starting off with a positive reputation.
carburetor
I have a 77 f350 460 4bbl
I just noticed that the air filter hold down is stripped inside the carb.
Is there a way to fix this without removing the carb or replacing it?
I was thinking about epoxy but did not know if I put it into the threaded hole would it make its way into the carb
thanks steve
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 07-03-2008, 11:09 AM
x79f100x's Avatar
x79f100x is starting off with a positive reputation.
As far as I know, the threaded hole is isolated from the rest of the carb. I may be wrong though. Try using a flashlight to see a little better. Only use the minimum amount of epoxy if possible. Just remember that it will be hell to get out if you ever need to.
__________________
1979 F-100 Ranger Lariat
"Nuclear Banana"
  #3 (permalink)
Old 07-03-2008, 11:12 AM
fmc400's Avatar
fmc400 has a very good reputation on FTE.fmc400 has a very good reputation on FTE.fmc400 has a very good reputation on FTE.
What I want to know is, how did someone manage to strip that?
  #4 (permalink)
Old 07-03-2008, 11:16 AM
wb6vvv's Avatar
wb6vvv is starting off with a positive reputation.
There might still be some threads at the bottom of the hole. I would go to the hardware store and get a lenght of 1/4 X 20 threaded rod and see if it will screw into the carb and then just cut the top off at the appropriate lenght.
__________________
Gary
1977 F250 460 Hauler, 1986 T-Bird 3.8 V6
  #5 (permalink)
Old 07-03-2008, 11:20 AM
x79f100x's Avatar
Good question there too lol. Mine either doesnt go in at all or goes in straight, no cross-threading.
BTW. This is what i have now (sorry if off topic)
__________________
"Nuclear Banana"
  #6 (permalink)
Old 07-03-2008, 12:06 PM
wb6vvv's Avatar
Ok x79f100x, I gotta ask, where did you get that fancy hose?
Also, that is one nice looking truck.
__________________
Gary
  #7 (permalink)
Old 07-03-2008, 12:10 PM
x79f100x's Avatar
I got the whole setup on the Hot Rod Power Tour by Spectre Performance. They let me display the truck by their trailer the whole tour. Thanks for the compliment BTW.
__________________
"Nuclear Banana"
  #8 (permalink)
Old 07-03-2008, 12:11 PM
Blue Bomber is starting off with a positive reputation.
are you sure its lining up with the hole?? i know, stupid queston. but its better to ask.
__________________
1974 Ford F-100, Straight 6, 3 speed on the Tree, 2wd. mostly stock....for now!
(10/6) NEwS flaSh: new clutch, new gear oil in the tranny.
thoughts on fixing daily drivers: work now, sleep later
  #9 (permalink)
Old 07-03-2008, 12:13 PM
x79f100x's Avatar
Yeah, deff. make sure of that. Make sure you aren't (somehow???) cross-threading it.
__________________
"Nuclear Banana"
  #10 (permalink)
Old 07-03-2008, 02:43 PM
I just got the truck, so I dont know how it got stripped.
but I am pretty sure it is. I took the top off and tried threading the screw in alone, you can feel the threads but they dont grab. It runs fine so I didnt want to remove the carb if I didnt need to.
So.. if I use epoxy I am not all that worried about ever removing it , if the carb ever needs work then I will pull it and replace the part or whole thing.
thanks
steve
  #11 (permalink)
Old 07-03-2008, 02:47 PM
I just wasnt sure if the hole went thru or not . I dont want to drip epoxy into the carb.
  #12 (permalink)
Old 07-03-2008, 03:29 PM
JBradley500 is starting off with a positive reputation.
i dont know, but id have it tapped to a 5/16-18 and get threaded rod and a wing nut. you wont over tighten that threaded rod or wingnut by hand. JMO.
__________________
New Plan...
410ci, 10:1, AFD 57cc 2v Heads, Edelbrock Intake and Phenolic Spacer, 725 cfm Road Demon, Roller 219/222 @.050 .535 lift 108 lsa, Bee-Hives, Dual Roller Chain, ARP's, MSD Pro Billet, Hedman Headers, Milodon Pan and HV Water Pump.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
