Go Back   Ford Truck Enthusiasts Forums > Misc. > Electrical Systems/Wiring
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 07-03-2008, 08:35 AM
archangel is starting off with a positive reputation.
Where is the EEC connector on a 96 van???
I need to find the EEC connector on a 96 E series van with a six cylinder and it does not seem to be near the drivers side under the hood area.
Also, any one know where I can find a list of codes on line for the same vehicle?
__________________
Gray 1991 F250 standard cab, 7.3, E4OD, 3.55:1, stock wheels and tires.
Verified 19 mpg city taking off slow as hell the shutting down at red lights, and with the radiator grill blocked flush, no bed cover, "drag shoot" mirrors on I get 24 mpg at 50 to 55 mph on the freeway empty!
However, with a bed cover, no mirrors and Hydroxy
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 07-03-2008, 09:04 AM
Conanski's Avatar
Conanski has a good reputation on FTE.Conanski has a good reputation on FTE.Conanski has a good reputation on FTE.
If your '96 is under 8500lbs GVWR then it is OBD2 and the diagnostic connector is in the cab under the dash.
__________________
Paul O
1990 F150 4x4 XLT X-Cab 5.0, 3.55, Comp 35-349-8, Flowtech LT's to 3" single, FRPP Mass Air Conversion
Under construction: '85 351HO, Dart Iron Eagles, Roller Rockers, Typhoon intake, Crane 444232, 24lb Injectors, TweecerRT, Innovate LC-1 wideband O2
1990 Ranger 2wd, 2.3 Briggs & Stratten, 5-speed, 3.08 gears, sliding rear window.
  #3 (permalink)
Old 07-03-2008, 05:39 PM
Franklin2's Avatar
Franklin2 has a great reputation on FTE.Franklin2 has a great reputation on FTE.Franklin2 has a great reputation on FTE.Franklin2 has a great reputation on FTE.Franklin2 has a great reputation on FTE.
You can find the codes here.
Decoders, Codes, Charts, Etc. .: Articles
__________________
Dave F
1989 F250 XLT Diesel
  #4 (permalink)
Old 07-03-2008, 09:26 PM
Quote:
OBD2?!?!
I guess that implies my old 1990 Rotunda scanner II will not pull the codes?
A guy I work with said he took it to a dealership and they told him there were no codes, but the OD light on the shifter is flashing, and there is a hard first to second shift that I associate with center support that has grooves worn into it from the forward hub.
__________________
  #5 (permalink)
Old 07-04-2008, 10:37 AM
Franklin2's Avatar
96-up is OBDII. The flashing light does indicate a tranny code or problem.
__________________
Dave F
  #6 (permalink)
Old 07-05-2008, 01:07 AM
Quote:
That's what I told him.
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
