Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 07-03-2008, 01:13 AM
hucka1a's Avatar
Just Trying to Learn
hucka1a has a good reputation on FTE.hucka1a has a good reputation on FTE.
I got a free super chips programmer
A buddy of mine gave me his super chips programmer. I know it's not even in the same ball park with DP Tuner. So far I have only used it to scan codes. My question is, Can I go ahead and run this programmer AND be safe with my truck as is? I am hoping to get a 6.0 trans cooler, 4" exhaust, gauges, and a bts valve body all before April. So hopefully I can get Jody to work his magic at smokin'. I've had this programmer under my seat for a couple of weeks now, just waiting to get some supporting mods done. The suspense is killing me, so I figured I would ask the pros.
Thanks
__________________
Huck
early 99 (11/24/98)
F250, PSD, 4x4, auto, ec, short bed.
PAA Member 66
6637/wrapped by Pete, CCV Mod, Autometer Ultralites, 6.0 Trans Cooler, MKO 4",'05 Power Seats
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 07-03-2008, 01:23 AM
4inchlovin's Avatar
Best mod ever!------>
4inchlovin has a good reputation on FTE.4inchlovin has a good reputation on FTE.
you'll be ok... just don't run it on the highest setting and keep your foot to the floor for a long period of time. Your EGT's can get up there...
Nolan
__________________
Nolan
New Motor:
2001, F250, Ext. Cab, LB, 4x4, 6speed
4" turbo back exhaust, 6637 w/ custom Pete cover, Gooseneck, Cobra 148GTL w/102" whip
PAA #64
Member of the Northern California Forum:
http://www.ford-trucks.com/forums/forum90/
RIP JET:
Quote:
Originally Posted by SolidGround View Post
Give without remembering
Receive without forgettin
  #3 (permalink)
Old 07-03-2008, 01:34 AM
RubberDuck's Avatar
Death Row Inmate #1
RubberDuck has a very good reputation on FTE.RubberDuck has a very good reputation on FTE.RubberDuck has a very good reputation on FTE.
Run it! Like 4inch said, just don't stay in it long in the high setting, and definately don't tow.
__________________
RubberDuck
1995 F350 Crew Cab 4x4 dually
DIY Stage 2's
T.E. SD HPOP
Tymar HPX
FPR 70psi
RSB Diesel 140v IDM
Tymar Intake
3"DP to 5" stacks
DP Tuner 2 pos. w/ custom switch
Hot Pedal
Gear Vendors OD
Good bye No.3 I'll miss you.
RIP #17
  #4 (permalink)
Old 07-03-2008, 08:24 AM
mueckster's Avatar
Redneck Wrencher
mueckster has a very good reputation on FTE.mueckster has a very good reputation on FTE.mueckster has a very good reputation on FTE.
Quote:
Thanks
I had the old 60/80hp SCMT for a couple of years with no problems. The newer one, with the 3 settings, is supposed to run lower EGTs. I ran the tow setting most of the time. This was even before gauges and exhaust mods. No problems. Like said, just don't "keep your foot in it" for very long and you'll be OK.
__________________
-Roland-
'01 F-250 Lariat CC SB 4x4, DP Tuner, AFE II w/ Pete's Cover, ATS Compr & exh hsgs, Zoodad, SS HPX, IAH, EBPV, & Foil delete, 203* stat, Phantom gauges, MAP Reg, tank mods, DIY HD 4R100, 4" MBRP exh, H2O filter, shimmed FPR, Turbo Master, CCV trap, Procomp lift pump, CCK, TruCool, 140v IDM, GP LED
PAA Member #62
  #5 (permalink)
Old 07-03-2008, 08:31 AM
03_PSD's Avatar
Still Learning
03_PSD has a good reputation on FTE.03_PSD has a good reputation on FTE.
i ran superchips also and towed with it, but i had gauges. egt's never got in the red zone for me, keep in mind i never tow like i stole it either.
__________________
Glenn Hook'Em Horns
2003 F250 CCSW Lariat 6 Speed~ProComp Lift~Ranch Hands Front and Back~3 Gauge Pillar~4" Exh. 6" Tip~6637 and Pete's Filter Cover~WW~AIH Delete~ SS HPX~Foil Delete~Alum. Rear Diff Cover~203 Tstat and Billet Housing~Recon Smoke Cab Lights~International Emblems~Fumoto Plug~Reverse Lights~TS Chip~Mildly Upgraded Audio
  #6 (permalink)
Old 07-03-2008, 09:04 AM
zx250's Avatar
Spread the wealth my ass!
zx250 is a name known to allzx250 is a name known to allzx250 is a name known to allzx250 is a name known to allzx250 is a name known to allzx250 is a name known to all
I ran the superchips 1705 for a couple of years and I will tell you that towing, you can push the EGT's pretty high if you stand on it for long. Use the 60 hp if towing much weight at all. Leave the top setting alone as I never saw anything other that extra high EGT's in that setting, no power gains at all over the 90hp. The SC tuner is worth every penny you paid for it, not much more. It does come in handy as a code reader, but once you go DP, you will know what a real chip is.
  #7 (permalink)
Old 07-03-2008, 09:33 AM
miller_feed's Avatar
Hook it, I'll pull it.
miller_feed is a splendid one to beholdmiller_feed is a splendid one to beholdmiller_feed is a splendid one to beholdmiller_feed is a splendid one to beholdmiller_feed is a splendid one to beholdmiller_feed is a splendid one to beholdmiller_feed is a splendid one to behold
I ran the 3 tuner superchip for 4 years, with only the muffler delete. I didn't mod my truck till I found FTE. I pulled heavy loads with it, but I changed tunes for what I was doing. Put it in and enjoy the extra power.
__________________
RICK, PAA MEMBER #4
2001, F-350, DRW. CC. LWB, 4X4, LARIAT,
MODS: 6637 W/Pete's filter cover, BTS-VB, DP-TUNER- stock, 40t, 60t, 80e, 140s, HI, OBA, 203*, billet housing, IH bolts, MBRP 4" SS, Isspro 3 gauge kit, Zoodad, Foil delete, TN-BB turbo, Bellowed up pipes, HPX, TRU-COOL cooler. For now.
Jim, Roland, Will, JD? I want to go somewhere.
  #8 (permalink)
Old 07-03-2008, 09:54 AM
MTDewX's Avatar
MTDewX is starting off with a positive reputation.
if you dont get into it to much, you will get better mileage for road trips. I have a diablo for that same reason. then of course till I get DP it will never be the same so I heard.
  #9 (permalink)
Old 07-03-2008, 10:39 AM
big poppa pump's Avatar
LOW RIDE RRR>>>>>>>>>>
big poppa pump is a name known to allbig poppa pump is a name known to allbig poppa pump is a name known to allbig poppa pump is a name known to allbig poppa pump is a name known to allbig poppa pump is a name known to all
Quote:
Same here, ran my SC for about 4 years now before i knew about FTE. Run it, its different than stock, trans will tighten up the shifts, more throttle response but as these guys and gals say, its no DP. Wished i would have known
__________________
Mike 2003 f-250 XLT CC 7.3 SB, auto, 4x4 373,s S-B air intake w snorkel,DP Tuner-NS,Stock,60T,80E,120R,140A, WW, CCV mod, SC Codereader, Isspros 3 pillar, foil del, MBRP 4 in duals, 285 Yoko,s A-T, Bilsteins, 2in shackle kit (Thanks Zack7.3), Zdad, CrimeStopper Alarm w remote start, Cobra 29 cb dual firesticks. PAA MEMBER 26#
  #10 (permalink)
Old 07-03-2008, 10:45 AM
Mike F250 is starting off with a positive reputation.
And then there's that annoying 45mph shift into OD. I still use the SC 1705 as I'm waiting for a few more mods to get the DP chip. I have mine set on the highest HP now for the first time in over a year. When others tell you don't stand on it for long, it is just seconds till my boost and EGTs are higher than they should be. So, play in the mid setting and get guages as soon as you can
__________________
Mike
2001 F250 XLT CC SB 4X4 7.3 PSD - afe stage 1, zoodad, ss hpx, a pillar trans-turbo-pyro gauges, hutch, harpoon, CCV mod, superchip
1974 F100 390ci - stock. fully restored. Grandpa was first owner, I'm 2nd.
  #11 (permalink)
Old 07-04-2008, 12:05 AM
Lovin7.3's Avatar
PAA #28
Lovin7.3 is gaining momentum as a positive member of FTE.
I had one on my old 99 and pulled with it on the high setting all the time. Just watched the egts. (6speed btw)
__________________
Zach -- PAA #28
Psycho Soot Diesel
Lafayette, Indiana
99.5 F-250 7.3L Auto 5" turbo back, Banks Six Gun, Autometer Boost, Autometer Trans Temp, DP Tuner (no start, stock, 80E, 120race) HPX, WW, non-ebps pedistal, bellows kit, zoodad
  #12 (permalink)
Old 07-04-2008, 12:39 AM
Tenn01PSD350's Avatar
Miller Brewing Co
Tenn01PSD350 has a great reputation on FTE.Tenn01PSD350 has a great reputation on FTE.Tenn01PSD350 has a great reputation on FTE.Tenn01PSD350 has a great reputation on FTE.Tenn01PSD350 has a great reputation on FTE.Tenn01PSD350 has a great reputation on FTE.
Quote:
That's where I had Jody set mine to shift at. I like my economy. I can defeat it with the OD cancel button. My truck can putter/loaf along at 45 in OD all day long, lugging if you want to call it that but egts never are an issue now with my setup.
__________________
2001 350 4X4 AUTO, GTP38R, Swamps Hybrids, DPTuner live tuned, PMRs
399.99/789.54
Mike
  #13 (permalink)
Old 07-04-2008, 01:28 PM
greystroke is starting off with a positive reputation.
1705
I have the 1705 superchips. I installed the Tow Safe program in my 97. Put about 50000 on it without a problem.
I am going to install it in my 2002 just as soon as I have enough baseline data on fuel consumption. Right now I am getting 15 to 22 depending on conditions. I am hoping for a mileage increase when I installed it. I am an old lady driving type.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
