Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1987 - 1996 F150 And Larger F-Series Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 07-03-2008, 01:00 AM
Mike124 is starting off with a positive reputation.
351w Gas Mileage Question
What kind of gas mileage can i see in a 91 F250 Reg Cab Long bed 4wd with 351w & 4-Spd Auto?
My driving habit is 50% city, 50% highway, i drive at speeds between 35-65MPH.
__________________
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 07-03-2008, 02:13 AM
DJdemon6696 is starting off with a positive reputation.
about 10 to 12
__________________
Under Construction: 1989 F150 reg cab 8ft bed, currenty its a i6 4.9
Building An: 5.0 HO, Comp custom cam , Flowtech, GT40 heads, Edelbrock intake/ Holley Carb, to drop into it..
'90 F250 351, [sold]
  #3 (permalink)
Old 07-03-2008, 02:20 AM
Quote:
Originally Posted by DJdemon6696 View Post
about 10 to 12
10-12 ain't bad for early 90's full-size 4wd with v-8 so i'll add it to my list, t
thanks for info.
__________________
  #4 (permalink)
Old 07-03-2008, 02:22 AM
jepp im getting 9 -11 all city driving.. and i drive like a 16 year old so.. maybe you can exect better... even better if you gave it a tune up
Plugs
Wires
cap / Rotor
offcourse oil and oil filter
__________________
  #5 (permalink)
Old 07-03-2008, 03:20 AM
Plugs
Wires
cap / Rotor
If i get the truck gone get K&N air intake, dual exhaust, do full tune-up, change all fluids get oil & trans filters an swap out the mud tires for all-terrains.
__________________
  #6 (permalink)
Old 07-03-2008, 06:54 AM
alz alz is offline
alz is starting off with a positive reputation.
I would skip the CAI setup. Just use a drop in.
__________________
1995 F150 4x4 SC 302 4R70W MAF
  #7 (permalink)
Old 07-03-2008, 08:40 AM
Conanski's Avatar
Conanski has a good reputation on FTE.Conanski has a good reputation on FTE.Conanski has a good reputation on FTE.
Depends on the gearing, DJ has 4.10's in that truck so it's going to be thirsty anyway. I get roughly 13 cty and 17+ highway with my truck and 3.55's, a good exhaust system makes a big difference on these trucks too.
__________________
Paul O
1990 F150 4x4 XLT X-Cab 5.0, 3.55, Comp 35-349-8, Flowtech LT's to 3" single, FRPP Mass Air Conversion
Under construction: '85 351HO, Dart Iron Eagles, Roller Rockers, Typhoon intake, Crane 444232, 24lb Injectors, TweecerRT, Innovate LC-1 wideband O2
1990 Ranger 2wd, 2.3 Briggs & Stratten, 5-speed, 3.08 gears, sliding rear window.
  #8 (permalink)
Old 07-03-2008, 11:11 AM
alxsnmr is starting off with a positive reputation.
Highway speed is a factor too, My bronco with a C-6 averages 10 mpg in mostly city driving of stop-n-go and 70+ mph driving. I took a trip with it and stayed within 55-60 mph and averaged 13 mpg amazing and inconsistant though.
__________________
Stock 1978 F250 Custom regular cab 4x4 with 351M and 4 spd.
1991 Bronco silver anniversary, 5.8L EFI, E4OD swapped for C-6, otherwise still stock.
  #9 (permalink)
Old 07-03-2008, 11:12 AM
Kemicalburns's Avatar
Kemicalburns is gaining momentum as a positive member of FTE.Kemicalburns is gaining momentum as a positive member of FTE.
run a drop in K&N filter, running a good aftermarket set of headers,Ypipe and stay with a single 2.5-3" exhaust for the best mpg results. duals will not help in the mpg relm.
__________________
94 XLT 5.8/E4OD
6"ProComp Stage II 35x12.5x15 BFG MT's ,
4.88 gears f/r
installing soon: JBA shorty, Bassani Y pipe, Edelbrock efi truck intake, , aussie front/rear
88 (Rolled)
http://www.supermotors.org/registry/vehicles/detail.php?id=4158
  #10 (permalink)
Old 07-03-2008, 08:53 PM
Quote:
The truck already has factory dual exhaust, both pipes exits behind passenger rear tire.
__________________
  #11 (permalink)
Old 07-03-2008, 10:42 PM
Dustin1690 is gaining momentum as a positive member of FTE.Dustin1690 is gaining momentum as a positive member of FTE.
Should get between 10-15 like everyone said depends on gearing driving habits everything in tip top shape etc
__________________
Dustin - Southern Saskatchewan Canada
My Truck:
1993 F150 XLT Reg cab Long box 351 (5.8L) E4OD 2wd 3.55 non limited slip axle factory ten hole aluminum rims
Dad's Truck:
1992 F150 XLT Supercab Short box 302 (5.0l) E4OD 2wd 3.55 non limited slip axle factory five star wheels
2006 F150 XLT Supercrew 5.5ft box XTR 5.4l 4R75E 3.73 LS 4x4
  #12 (permalink)
Old 07-03-2008, 10:51 PM
Thanks for reply guys, i've got a couple of other vehicles to check out on my list but most like gonna go with F250 since other's have between 130-180K an F250 got 106K on it.
__________________
  #13 (permalink)
Old 07-06-2008, 05:26 PM
crestfallinman is starting off with a positive reputation.
from what i hear its like 10-15 mpg for the 351 and i have a 300 that gets like 10...
if this is true then y havent i changed the engine yet?
__________________
1994 f150
40k original miles
lightning rims
"county brown" paint
  #14 (permalink)
Old 07-06-2008, 05:33 PM
Don't own the truck, thinking of buying it.
__________________
  #15 (permalink)
Old 07-06-2008, 06:04 PM
frederic's Avatar
frederic has a great reputation on FTE.frederic has a great reputation on FTE.frederic has a great reputation on FTE.frederic has a great reputation on FTE.frederic has a great reputation on FTE.
You'll find that all the gas engines, 300, 302, 351, 460 get pretty much the same mileage in an unloaded pickup if you drive them reasonably nicely. The difference is when you romp the throttle or load the truck up quite a bit - the bigger engines will drink more, but haul more.
Like others have said, tire diameter, gearing, shift points, overall tune and such certainly impacts mileage.
The biggest factor is your right foot, and that foot is directly connected to your wallet.
My 500K F350 crewcab (351W/5sp) gets about 13-14 on the highway, down from it's consistent best of 16ish many years ago. But it's not a fair parallel to the trucks you're considering because mine weighs quite a bit more, it's a stick, and I shift it very early to be frugal with the power, meaning also I'm being frugal with gas and in turn, my dollars.
Plus with lower RPMs, they last longer
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
