Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Super Duty And Heavy Duty
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 07-03-2008, 12:38 AM
badluck b is starting off with a positive reputation.
tranny dipstick leaking WTF?
So I moved my 99 f250 powerstroke for the 1st time in a few weeks and it starts leaking fluid from the dipstick tube at the top. I pulled the dipstick and it spewed all over. Wtf?
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 07-03-2008, 12:45 AM
75F350's Avatar
75F350 has a very good reputation on FTE.75F350 has a very good reputation on FTE.75F350 has a very good reputation on FTE.75F350 has a very good reputation on FTE.
Welcome to the site:
Sounds like the truck is mad because it was parked for too long, and it is letting you know that it needs love too.
All kidding aside, I do believe that you have a blocked vent. The vent is located on top of the trans. Air has to move out when the fluid heats and expands, and if it cant vent pressure will build, and it will find a way out. The dipstick is the easiest.
  #3 (permalink)
Old 07-03-2008, 03:11 AM
aldridgec's Avatar
aldridgec is gaining momentum as a positive member of FTE.
Bugs like the hole and could be living in the vent clogging it. Also mud daubers.
__________________
Chris
ASE Certified Master Automotive Technician
Current Vehicles:
2002 F-250 7.3L PSD 4x4 XLT
2002 Sunset Orange Mettalic WS6 Trans Am Convertible
"Maybe is for those who lack skill"
  #4 (permalink)
Old 07-03-2008, 08:34 AM
thanks guys. What does the vent look like and can I clean it without pulling the tranny?
  #5 (permalink)
Old 07-03-2008, 06:06 PM
I'll try to find the vent. I also heard it could be the torque converter draining back. Will it fill back up b running it or will it smoke the tranny?
  #6 (permalink)
Old 07-03-2008, 09:28 PM
F350-6's Avatar
Slow Typing
F350-6 is a splendid one to beholdF350-6 is a splendid one to beholdF350-6 is a splendid one to beholdF350-6 is a splendid one to beholdF350-6 is a splendid one to beholdF350-6 is a splendid one to beholdF350-6 is a splendid one to behold
The vent should be on top near the front of the tranny. I'm no tranny expert, but the fluid should be pumped through the torque converter. Since the fluid is pumped through the tranny, torque converter, and transmission cooler, the TC draining back sounds like it would only happen if you had a line blocked somewhere.
How old is your fluid? If the vent turns up clean and the fluid is old, maybe doing a flush will give you a better idea of what's going on. We have an excellent DIY article on the flush written by a member here Changing ATF Fluid in a E4OD and 4R100 transmission .: Articles
__________________
Chris
2002 F350 6-speed 444 CID. XLT, Heated Seat, 270,000 & counting. 6637 w/ Pete's armor. Cold air set up for 6637
“Good judgment comes from experience, and a lot of that comes from bad judgment.” Will Rogers
MORE (Military Online RElay)
  #7 (permalink)
Old 07-04-2008, 08:15 PM
Mark Kovalsky's Avatar
Mark Kovalsky has a great reputation on FTE.Mark Kovalsky has a great reputation on FTE.Mark Kovalsky has a great reputation on FTE.Mark Kovalsky has a great reputation on FTE.Mark Kovalsky has a great reputation on FTE.
The torque converter will fill by running the engine. It's the only way to fill the torque converter.
The torque converter will drain back because the anti-drainback valve has a slight leak. Plugged lines have nothing to do with it.
If you do use that excellent article to change your ATF, be aware that it is a bit out of date. Ford has discontinued MERCON and changed MERCON V to be compatible with all transmissions that used to use MERCON. So use MERCON V and ignore where it says not to.
__________________
Mark
Former Ford automatic transmission engineer, 1988-2007.
  #8 (permalink)
Old 07-04-2008, 08:24 PM
F350-6's Avatar
Slow Typing
Good info as always Mark. Any idea what he should be looking for in terms of shooting fluid out of the fill tube?
__________________
Chris
  #9 (permalink)
Old 07-07-2008, 06:34 PM
Thanks everyone
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
