Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 07-02-2008, 10:28 PM
kidkaden is starting off with a positive reputation.
Question 1984 5.0 302ci
I bought a 1984 - 5.0 302 Ci ford engine out of an E-100 van, i am rebuilding it. could some one give me some direction on what rods-valves-springs-cam-crank-piston etc. and what size i would need to beef up this engine, I'm going to have to bore it .10 due to wear
Thanks
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 07-02-2008, 11:21 PM
hayden01's Avatar
hayden01 is starting off with a positive reputation.
I've herd that you can take the crankshaft and a camshaft out of a 351W and put it into a 302 and it would turn it into a stroker motor. As far as the other after market parts go...I'm not sure. It's really all about what applacation you are going to be using it for i.e. off roading, mudding, daily driver, sleaper, drag. And also if you want monster low end torque or lots of ponnies under the hood.
__________________
'84 Bronco:
302:
-Edelbrock Performer 289 intake
-Holley 600cfm carb
-1" single plane carb spacer
-Flowtech headders
-Mild cam
Drivetrain:
-Stock NP 208 T-Case
-8.8 rear axle w/ 3.08 gears
-Dana 44 IFS front axle w/3.07 gears
-T170FT RTS tranny
Soon to Come:
-new gears
-electric fan
  #3 (permalink)
Old 07-03-2008, 08:59 AM
Conanski's Avatar
Conanski has a good reputation on FTE.Conanski has a good reputation on FTE.Conanski has a good reputation on FTE.
No.. the 351w crank won't go in a 5.0 block, the journals are way bigger.
I suggest you indicate what your budget is, what your power goals are, and what vehicle the motor will be installed in.
It's no problem to spend $1500 on a complete rebuild, and that can give you a stock motor or something much better than stock, it just depends what parts you buy. If you goals go beyond 300hp you will need different heads so factor that in before you spend a dime on the stock heads. If your goals are big power at low rpms then stop right now and go find a 351 or 460, the 302 will never be a TQ monster.
__________________
Paul O
1990 F150 4x4 XLT X-Cab 5.0, 3.55, Comp 35-349-8, Flowtech LT's to 3" single, FRPP Mass Air Conversion
Under construction: '85 351HO, Dart Iron Eagles, Roller Rockers, Typhoon intake, Crane 444232, 24lb Injectors, TweecerRT, Innovate LC-1 wideband O2
1990 Ranger 2wd, 2.3 Briggs & Stratten, 5-speed, 3.08 gears, sliding rear window.
  #4 (permalink)
Old 07-03-2008, 10:26 AM
IcemanV8's Avatar
IcemanV8 is starting off with a positive reputation.
What exactly are you wanting to do to it? Make it mild or wild? Make it a towing machine or a top end runner?
You mentioned about a crank. Are you wanting to make a stroker 331/347? 331 is the way to go down that route.
But, yeah, if you want gobs of power at low RPM, go for a 460.
__________________
1986 Ford F-150 4x4 5.0 EFI
XLT Lariat
NP435/NP208/9" 3.50 axle
Road Warrior bumper, Leaf Spring Overloads, Custom Exhaust Work
  #5 (permalink)
Old 07-03-2008, 01:49 PM
BaronVonAutomatc is starting off with a positive reputation.
If you're going to stroke it out go ahead and get a 347 kit. Folks talk about rod ratios...like the difference between 1.58 and 1.60 is a huge negative. More cubes = more power; and there are hundreds of 347 strokers out there reliably cranking out 450+ hp. Build it right and there are no worries. Then you've basically got a 351w less 125 pounds.
Check out the FRPP website and look at some of the crate engines Ford sells. That will give you a good idea of what kind of power you can get from different engine components. Stock rods and crank are fine unless you're shooting for 400+ hp. Comp XE cams are the best grind, unless you go custom. AFR heads are good for 60+ hp over stock.
__________________
1986 Bronco w/300 I6 & ZF 5-Speed
1982 F250 4x4 w/302 & C6
  #6 (permalink)
Old 07-05-2008, 10:32 AM
IcemanV8's Avatar
I'm not talking about rod ratios when I say the 331 is the way to go. I'm talking about longevity. Your engine is maxed when you go to a 347. You can make the same power with a 331, if you want 450 horsepower. But, whatever floats your boat, ya know?
__________________
XLT Lariat
  #7 (permalink)
Old 07-07-2008, 07:05 AM
hayden01's Avatar
Quote:
My black, sorry y'all
__________________
'84 Bronco:
302:
-Holley 600cfm carb
-Flowtech headders
-Mild cam
Drivetrain:
-T170FT RTS tranny
Soon to Come:
-new gears
-electric fan
  #8 (permalink)
Old 07-07-2008, 10:50 AM
LxMan1's Avatar
LxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to behold
The 331 is better if you are twisting up around 7000rpm+, 6500 and under, a 347 is fine.
They both have the same bore, so how is one maxing out over the other. Both are 4.030 bore???
For a street engine that isn't spun up to the moon, a 347 will have a bit more torque.
Years ago there was a buildup article where they built a 302 and 347 with the same set of heads, cam, compression, carb and intake. The only difference was the CI and the 347 made 100lb/ft more than the 302.
__________________
Jimmy- FTE Moderator
Support FTE....Online Store
88 5.0 LX Mustang
63 F100 351W/C6
  #9 (permalink)
Old 07-11-2008, 10:16 AM
78ltd is starting off with a positive reputation.
I have heard that the 347 stroker kits are not 100,000 mile turn key reliable.
Is that wrong? If it is, then I will consider that set-up when I rebuild the 'ol
79 T-Bird engine.
  #10 (permalink)
Old 07-11-2008, 01:44 PM
Conanski's Avatar
Quote:
Coincidentally.. you get similar results with 351, and the bigger windsor will easily go a couple hundred thousand miles.
__________________
Paul O
  #11 (permalink)
Old 07-13-2008, 12:13 PM
I don't know why a 347 - competently machined and built with a new (not offset ground) crank, new rods (with better-than-those-flimsy-stock rod bolts), and new hyper or forged pistons - wouldn't last 100,000+ miles. Moderately built for street use and properly maintained there are no worries.
I mean, it's not like a 302 has never blown up. I saw a well-maintained, relatively low mileage 302 blow up trying to push an F250 into a gusty 30-40 mph headwind at interstate speed. It boils down to how it's built, how it's used, and how one takes care of it.
__________________
  #12 (permalink)
Old 07-13-2008, 01:31 PM
Conanski's Avatar
It's not likely a well built 347 would blow up any sooner than a 302 or 351, but that motor does have 1 downside.. if you will. The necessary rod length and short deck height leaves little room for piston rings, so the piston pin is moved up into the oil ring and the other rings are moved closer together. This has resulted in more oil consumption and some ring land failures in the past on this stroker.
__________________
Paul O
  #13 (permalink)
Old 07-13-2008, 10:46 PM
Stroker
Yup, I heard it was pin/ring issues caused by the long rod and
short piston skirt. They are OK if used to race with the knowledge
you will be rebuilding it every so often, but not OK to use long
term with turn key reliability when all you want is the extra torque,
not high rpm HP. In a 4200 pound 'bird, I'd probably do better
with a 351 swap.
  #14 (permalink)
Old 07-14-2008, 05:10 PM
hayden01's Avatar
Oh yeah. I recon that the "V8modify it to the max to get the most power out of it, then get a gigger engine and build that on up to supass the old engine" bug has indeed bit me and intoxicated me with the "more power" bug!!!! for those of you who have watched the TV show Home Improvment" you know what I'm talking about. More Power!!!!
__________________
'84 Bronco:
302:
-Holley 600cfm carb
-Flowtech headders
-Mild cam
Drivetrain:
-T170FT RTS tranny
Soon to Come:
-new gears
-electric fan
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
