Go Back   Ford Truck Enthusiasts Forums > Misc. > Electrical Systems/Wiring
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 07-02-2008, 09:58 PM
1957F100 is starting off with a positive reputation.
Heavy Duty Headlight Harness
Ive been looking into getting a upgraded headlight harness for my truck. I was just wondering if any of you guys have these harnesses and what you think of them?
Ive read on the internet that since they pull power from the battery you get brighter lights and since the headlight switch is no longer pulling the power they wont overheat and melt, which is suppose to be a common problem.
It says daytime running lites must be disabled to use this harness. Does anybody know why? and how would i disable my DRL? Also do any of you guys have HID lights? I would like to get a set in the near future and i was wondering if i would be able to use this harness with HID lights?
__________________
1957 Ford F100 - 302 w/ C4. Work in Progress...
1993 Ford F250 4x4 - 7.3L Diesel, ZF 5 Speed
Mods - Soup Bowl Removed. Hypermax Cowl Air System Installed. Autometer Ultra Lite Gauges. South Bend Clutch.
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 07-02-2008, 10:15 PM
Franklin2's Avatar
Franklin2 has a great reputation on FTE.Franklin2 has a great reputation on FTE.Franklin2 has a great reputation on FTE.Franklin2 has a great reputation on FTE.Franklin2 has a great reputation on FTE.
The DRL circuit is integrated into the original harness, and is somewhat like a "3rd mode" for the lights. The aftermarket harness is only designed for 2 modes, high and low beam. The instructions in your link tell you how to disconnect the DRL's.
The harness does make the lights brighter, and there is a theory that it will shorten the life of the bulbs because of the higher voltage, but even if the life was shorter, the benefits outweigh the shorter lifespan.
__________________
Dave F
1989 F250 XLT Diesel
  #3 (permalink)
Old 07-02-2008, 10:32 PM
yeah im not worried about shortening the liftspan of my lights. i cant remember when the last time was i had to change headlights in a vehicle because they died.
i just found the part about disconnecting the DRL. apparaently i just unplug it from the module on the rad support on the drivers side.
now i just need to make sure i can use them if i decided to get some HID lights.
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
