Go Back   Ford Truck Enthusiasts Forums > Misc. > Appearance & Dress-Up
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 07-02-2008, 09:57 PM
1957F100 is starting off with a positive reputation.
Heavy Duty Headlight Harness
Ive been looking into getting a upgraded headlight harness for my truck. I was just wondering if any of you guys have these harnesses and what you think of them?
Ive read on the internet that since they pull power from the battery you get brighter lights and since the headlight switch is no longer pulling the power they wont overheat and melt, which is suppose to be a common problem.
It says daytime running lites must be disabled to use this harness. Does anybody know why? and how would i disable my DRL? Also do any of you guys have HID lights? I would like to get a set in the near future and i was wondering if i would be able to use this harness with HID lights?
__________________
1957 Ford F100 - 302 w/ C4. Work in Progress...
1993 Ford F250 4x4 - 7.3L Diesel, ZF 5 Speed
Mods - Soup Bowl Removed. Hypermax Cowl Air System Installed. Autometer Ultra Lite Gauges. South Bend Clutch.
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 07-04-2008, 10:38 PM
ReAX's Avatar
Molon Labe
ReAX is gaining momentum as a positive member of FTE.ReAX is gaining momentum as a positive member of FTE.
I had a kit from painless wiring and it was amazing. Nice relays and pretty heavy duty wires.
The reason they say to disable the DRLs is some DRLs operate by putting half voltage to the low beams. That voltage is enough to power the relays which will dump full voltage/current into the bulbs while the DRLs are active.
That is correct about the wiring, there is less flicker and better current flow since the power isn't running all around the truck through small gauge stock wires. If you are using HIDs you don't need this, they work much the same way, the stock wiring trips a relay in the ballast and the ballast draws it's current from the battery.
__________________
Too many mods to list, so click here.
-MECP 06/27/08
Look, see these two tow hooks? They look like tusks. And what kind of animal has tusks?
there's a very fine line between not listening, and not caring. I like to think that I walk that line every day of my life.
  #3 (permalink)
Old 07-05-2008, 01:18 AM
so HID lights connect to the battery somehow then? i thought HIDs just plugged into the stock headlight plug?
__________________
  #4 (permalink)
Old 07-05-2008, 07:59 PM
ReAX's Avatar
Molon Labe
Good kit should plug into the stock head light harness to get the signals to activate high and/or low beams (depending on the kit), then the ballast should be connected to the body ground and the battery for it's primary power. HIDs should consume a whole lot more power than conventional bulbs, I wouldn't install a ballast without it's own power source.
So far all of the kits I have come across have been this way.
__________________
-MECP 06/27/08
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
