335 sections slow. what water pump are you running?
I figured since nothings been going on alot around here, id ask a question. i just got a weiand high flow aluminum water pump. it is supposed to flow 30% more than a stock, but its probably based on their small block chevy ones. is there any real down side to high flow except price and needing a different thermostat?
whats everyone else running for pumps? stock, aluminum, high flow or a combo of them?
yeah its kind of a dumb question but the small parts make the biggest differences in performance and reliability.
__________________
New Plan...
410ci, 10:1, AFD 57cc 2v Heads, Edelbrock Intake and Phenolic Spacer, 725 cfm Road Demon, Roller 219/222 @.050 .535 lift 108 lsa, Bee-Hives, Dual Roller Chain, ARP's, MSD Pro Billet, Hedman Headers, Milodon Pan and HV Water Pump.
i am running stock pump with a markvlll electric fan and 180 thermo stock 2 core rad. have not drove any long trips of traffic jams yet to see how well it cools, but driveing around town and in the country have had no over heating problems. what is the weight diff between alum and cast.
I was considering the Flow-Kooler, only because they seem to have put some thought into the design - and it's about 50% of the cost of the Weiand or Edelbrock pieces.
I run th Flow-Kooler aluminum. I also have the Lincoln electric fan with a DC controls fan control. I have never had a problem. Just make sure you use anti-seize with the aluminum or it will fuse with the bolts.... major PITA.
