Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 07-02-2008, 07:08 PM
King0581 is gaining momentum as a positive member of FTE.King0581 is gaining momentum as a positive member of FTE.
Diy Aic
Ok so I've read a couple threads on this and then went out and looked at my '03 and I have one plug on the left side of the pedal at the top and it has 5 wires coming out of it. They are red with yellow tracer, red w/ green tracer, gray w/ white tracer, yellow, brown w/ white tracer. In the threads I have read the IVS and TPS are two seperate items. One has two wires and one has three coming out if it. I have seen a thread that cookie 88 did and his was a four wire hookup using a Red w/ yellow, red w/ green, grey w/ white and a black w/ white. My question is on my '03 is the IVS and the TPS all one deal? Cause all the wires will match up with cookies wiring except the black w/ white wire which the brown wire on my truck could be black(not real sure). Any help with this would be much appreciated. Thanks!
__________________
Lee '03 F250 SC 4x4, 7.3,6 speed. Edge Evo 2,6637, CCVmod, catch can, shimmed FPR, EBPV brake, King style Zoodad mod, Cold AC, WW, Hutch and Harpoon, prepump filter. Leveling kit. 203* stat, coolant filter. 4"ststl MBRP, DIY AIC,fumoto.
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 07-02-2008, 09:08 PM
ron's power stroke's Avatar
FORD the rock crusher
ron's power stroke is a splendid one to beholdron's power stroke is a splendid one to beholdron's power stroke is a splendid one to beholdron's power stroke is a splendid one to beholdron's power stroke is a splendid one to beholdron's power stroke is a splendid one to behold
bump........AIC ?? my mind draws a blank,,sorry
__________________
Early 99 7.3 F350 auto,AFE stage2 5" strait pipe. DP tuner ,140 IDM,Modified 17* HPOP..DI RR
Ryan Casserly's SS stage 2's moded 100% over nozzles
exploded view of a 7,3
Reconstructed 7point3.com
  #3 (permalink)
Old 07-02-2008, 09:10 PM
PETE'S_7.3PSD's Avatar
Coal mine driver
PETE'S_7.3PSD has a good reputation on FTE.PETE'S_7.3PSD has a good reputation on FTE.PETE'S_7.3PSD has a good reputation on FTE.
Hi idle? maybe just shooting in a dark Ron
Automatic Idle Control?
maybe im just making new names here. LOL
__________________
2005 King Ranch Dually 6.0
SCT loaded with Spartan tuned on the desk and Magnaflow duals 4" turbo back in the mail
PARTS FOR SALE
BTS Trans -3200$ pm for details
RR CPR+ for sale 450$ PM for details.
  #4 (permalink)
Old 07-02-2008, 09:15 PM
a-rod's Avatar
a-rod is gaining momentum as a positive member of FTE.
glad im not the only one getting lost with all these abreviations
__________________
Adam - - Collision/Refinishing Tech
2002 7.3 POWERSTROKE
100,000 miles
Straight Pipe, 6637, HPX line, pryo gauge, Foil Delete, WW, 6.0 IC + TC. Superchips Tuner.
F-350 Rear Blocks, Leveling kit
  #5 (permalink)
Old 07-02-2008, 09:16 PM
Coal mine driver
Quote:
LOL no you not
__________________
PARTS FOR SALE
  #6 (permalink)
Old 07-02-2008, 09:17 PM
UP_There's Avatar
R.I.P. JET
UP_There is a name known to allUP_There is a name known to allUP_There is a name known to allUP_There is a name known to allUP_There is a name known to allUP_There is a name known to all
I read it earlier and had no clue as well haha
__________________
Travis PAA Member #5.0
2000 F250 4x4 PSD with THE DP-TUNER &
a couple "other things"
LOOKIE!----> http://www.ford-trucks.com/forums/79...-the-week.html
  #7 (permalink)
Old 07-02-2008, 09:21 PM
DO IT YOURSELF AUXILIARY IDLE CONTROL. Dang Caps. My question is, is the TVS (throttle validation switch) and the TPS (throttle position sensor) in the same little box deal on my truck? It appears that on the older trucks they were separate, but my truck has the same colored wires coming out of the box at the top of my fuel pedal.
__________________
  #8 (permalink)
Old 07-02-2008, 09:24 PM
Coal mine driver
there you go the guessing game is over LOL
cant help you there i have DP with hi idle. maybe somone with DIY kit will chim in
__________________
PARTS FOR SALE
  #9 (permalink)
Old 07-02-2008, 11:23 PM
mueckster's Avatar
Redneck Wrencher
mueckster has a very good reputation on FTE.mueckster has a very good reputation on FTE.mueckster has a very good reputation on FTE.
Quote:
Your '03 does have the all-in-one IVS/TPS sensor on the pedal.
The instructions, I used for the AIC, show a brown with white stripe. All the other colors are correct.
Just follow the directions and you'll be OK. I forget what resistor I ended up using, but it put the rpms at about 2500 at full knob. PM me if you have any other ???s.
__________________
-Roland-
'01 F-250 Lariat CC SB 4x4, DP Tuner, AFE II w/ Pete's Cover, ATS Compr & exh hsgs, Zoodad, SS HPX, IAH, EBPV, & Foil delete, 203* stat, Phantom gauges, MAP Reg, tank mods, DIY HD 4R100, 4" MBRP exh, H2O filter, shimmed FPR, Turbo Master, CCV trap, Procomp lift pump, CCK, TruCool, 140v IDM, GP LED
PAA Member #62
  #10 (permalink)
Old 07-03-2008, 06:18 AM
Thanks Roland! I just wanted to be sure before I went to splicing into wires. Maybe it was just a misprint in the instructions I got. Just waiting on my switch from mouser now.
__________________
  #11 (permalink)
Old 07-03-2008, 08:05 AM
mueckster's Avatar
Redneck Wrencher
Thumbs up Good Deal!
The AIC provides higher rpm for extended idling and faster warm up. But, I like the fact it gives me the ability to adjust the rpms when I'm working on the truck, checking things out, by myself.
__________________
-Roland-
PAA Member #62
  #12 (permalink)
Old 07-03-2008, 10:51 PM
Good plan there! Hadnt thought of that benefit!
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
