it depends pretty much how the techs wire up the systems. Is as designining a system, some do a good job some do a poor job.
I believe you will still be able to use that lock after an alarm has been wired up as long as it's independent and only triggers your solenoid on door.......
the only thing is you may have them just wire up glass sensor, proximity and shock but only locking of the foor doors with the exception of your drivers (which contains the lockpad)
That's my opinion.....yes it is going to be a complex wire up but if tech knows what he is doing, can be done....
Goodluck.
