Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1980 - 1986 F100, F150 And Larger F-Series Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 07-02-2008, 04:11 PM
yukgoon is starting off with a positive reputation.
Rear Axle Oil Seals
I have an 82 F-100 4x2 that I am redoing the bearings on. I pulled out the axles changed the bearings but cannot find anyone that stocks the oil seal that sits inside the axle shaft. It feels almost rubbery on the inside and yet has a metal exterior. Any one every come across this hand what did you do to remove it and replace them.
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 07-02-2008, 09:16 PM
DirtStripHero's Avatar
DirtStripHero is starting off with a positive reputation.
I believe you are talking about a pinion seal. I just put a new one in my F350. I had to tear up the seal to get it out. But you can use any combination of a screwdriver, chisel, punch, and hammer and pry it out. There should be a lip on the outside, if you can get a screwdriver or chisel down there, then you can pry it out that way. I bought my seal at a local auto parts store. Most of them should carry it, Autozone, Speedway, or Napa.
__________________
Michael
2000 F-150 4.2L, 5spd, 3.55, 4x4
1984 F-350 6.9L 2wd, T-19
1980 F-250 460, c6, 4x4, pulling truck, many mods to come when money becomes available
  #3 (permalink)
Old 07-02-2008, 10:32 PM
Franklin2's Avatar
Franklin2 has a great reputation on FTE.Franklin2 has a great reputation on FTE.Franklin2 has a great reputation on FTE.Franklin2 has a great reputation on FTE.Franklin2 has a great reputation on FTE.
Is this it?
http://www.partsamerica.com/ProductD...pe=293&PTSet=A
__________________
Dave F
1989 F250 XLT Diesel
  #4 (permalink)
Old 07-03-2008, 12:41 AM
The seal I am talking about is on the outer part of the axle shaft housing away from the differential. It sits next to the axle bearing next to the drums.
  #5 (permalink)
Old 07-03-2008, 05:56 PM
Franklin2's Avatar
The seal in the link above is called a "rear wheel" seal.
__________________
Dave F
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
