Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Super Duty And Heavy Duty
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 07-02-2008, 03:04 PM
LSAtexan4x4's Avatar
LSAtexan4x4 is starting off with a positive reputation.
Question better wheel option?
i am looking at the XD hoss wheel and 4wp has two specs listed * Back Spacing = 5.18 in. * Offset = 30 mm. * Hub Bore = 125.5 * Finish = Black and this one * Back Spacing = 5.70 in. * Offset = 18 mm. * Hub Bore = 125.5 * Finish = Black which is better for 38x15x18 inch tires and there both 18x9
__________________
2002 F-250 Superduty XL
supercab
4x4
Mods: Towing Mirrors, bucket seats with console
Future Mods: Tint, 8'' icon lift w/ 37'' toyos, front replacement, sound system, get rid of the xl headlights and go with an 05 style
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 07-02-2008, 03:06 PM
sorry if thats confusing i had it spaced diff
__________________
supercab
4x4
  #3 (permalink)
Old 07-02-2008, 04:39 PM
Beerstalker's Avatar
Beerstalker has a very good reputation on FTE.Beerstalker has a very good reputation on FTE.Beerstalker has a very good reputation on FTE.
I think you may have your offset's mixed up. The 5.18" backspace should have the 18mm offset, and the 5.7" backspace should have the 30mm ofset.
5.18-4.5 = 0.68x25.4 = 17.3mm
5.7-4.5 = 1.2x25.4 = 30.5mm
You would want the wheel with the least amount of backspacing since you have a 2002 superduty. So the 5.18 would be better for you.
I'm not real great with wheel stuff though, so you probably want to get a secodn opinion.
__________________
2007 F350 Lariat, CC, LB, 4x4
4.5" DR Lift w/35x12.5r20 Toyo Open Country M/Ts
Keystone Restyling Ram Air Hood W/Airaid Intake & Pre-filter
Recon Smoked Cab, Mirror, and Brake Lights
MSD Dashhawk w/A Pillar Mount
Dieselsite Coolant Filter
Lund Eclipse Window Vents
Weatherguard Toolbox
  #4 (permalink)
Old 07-02-2008, 05:29 PM
cartmanea is gaining momentum as a positive member of FTE.
You'll want the smaller backspacing to stay closer to stock and keep it from sticking out too much, but then you may have rubbing issues on the leaf springs. 15" is an awfully wide tire, if it were me I'd get the lower backspace and a narrower tire.
__________________
2003 F250 FX4 Sport, 6.0L Diesel, TorqShift Auto
- 4" Donahoe Racing springs, Bilstein shocks, 35" tires
- Off Road Tech winch bumper, powdercoated white
- SCT Xcal2 with Spartan tunes (ASE)
  #5 (permalink)
Old 07-02-2008, 07:25 PM
thats all i saw for the 38'' toyos nothin narrower.... but i may be mistaken....
__________________
supercab
4x4
  #6 (permalink)
Old 07-02-2008, 08:59 PM
DCSpecial's Avatar
FTE Sponsor
DCSpecial has a very good reputation on FTE.DCSpecial has a very good reputation on FTE.DCSpecial has a very good reputation on FTE.
With a 99-04 you'll want a wheel with 4.5" backspacing.
18x9 is too narrow for a 38/15.50.
And with over 5" of backspacing you will have a severly limited turning radius since your tires will hit the leaf springs.
Toyo makes a 38/15.50R18 and they also make a 38/13.50R18 in the Open Country MT.
__________________
  #7 (permalink)
Old 07-03-2008, 01:02 AM
I was thinking backwards in my first post...
__________________
  #8 (permalink)
Old 07-03-2008, 01:11 PM
Overkill's Avatar
FTE Sponsor
Overkill is gaining momentum as a positive member of FTE.
The KMC Hoss is also available in a 20x9 with -12mm offset (4.53" backspacing) which is more appropriate for lifted applications. I do agree though that the 20x9 Hoss will be too narrow for a 38/15.5.
See here for this and many other black wheel options: Black 20 Inch - Truck Toyz Store
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
