Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1987 - 1996 F150 And Larger F-Series Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #16 (permalink)
Old 07-04-2008, 10:27 PM
danr1 is gaining momentum as a positive member of FTE.
__________________
87, 94, 95 F250
89 Bronco II
96 Explorer
Sponsored Links
To remove this ad, register today!
  #17 (permalink)
Old 07-04-2008, 10:36 PM
jetedwards is starting off with a positive reputation.
thanks and when i test ohms on my multi it goes in increments of 2 ex 200 2000 20k 200k . so if i test something that should fall in the range of 20 to 70 ohms and get reading of 36 do i times that by 2 since the 200 hundred is twice as much as 100? weird kinda question dont no if all multi are like this or not mines a craftsman i believe
__________________
1997 F250 HD ext cab and full bed
1994 F350 suspension
5.8 230k miles
  #18 (permalink)
Old 07-04-2008, 11:35 PM
No the 20K setting is just more sensitive for reading smaller a value, values under 20K.
So if you're looking for a value of say "70K" use the 200K setting. 70K at the 20K setting should show "OL" (overload) or "error" depending on the meter. So bump up to the next higher setting and or "range".
__________________
87, 94, 95 F250
89 Bronco II
96 Explorer
  #19 (permalink)
Old 07-09-2008, 06:47 PM
swapped it after work today and could see the egr operate when i opened it up a little i then put the pld evr back and no movement so hopefully ill hav no check engine light tomorrow. if it is 2 days or more later than this post date it means it was all good and thanks again for getting my cel off
__________________
5.8 230k miles
  #20 (permalink)
Old 07-09-2008, 07:21 PM
and i just realized after reading another thread about this type of thing that i shoulda just grabbed this part at the junkyard. new it cost me $52 junkyard ill prob b 5 and i can test it in a miute so ill be returning the new 1. i made sure not to mess it or the package up.
__________________
5.8 230k miles
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
