Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1987 - 1996 F150 And Larger F-Series Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 07-02-2008, 12:21 PM
spidermonkey's Avatar
spidermonkey is starting off with a positive reputation.
ET gains with gt40 heads, BBK & basani exhaust
All,
After running the truck for a few weeks to make sure everything was together right, I took the truck to the fri night drags for a few passes.
Here what I got:
(all runs normally aspirated with 10 deg timing)
Stock best ET 16.856 sec @ 79.080 (1995 w/ 15K miles)
After adding gt40 heads, BBK shorty's, Basani Y pipe w/ cat, xcelerator straight through muffler:
Best ET 16.557 @ 81.680
So I gained about 3 tenths in ET and 2.6 mph. Initially I was disappointed, I was looking for a half a second gain, but after I started plugging the numbers into some HP calculators on-line these numbers are suggesting hp of 260 at the crank with about 210 at the rear wheels. 50 HP gain seems a little optimistic, but thats what the hp cal are saying. even if I gained 35 hp with the mods I'd be happy.
I have to keep reminding myself that this is a 4900 lb truck and not a mustang where the same mods may have yielded a .5 sec gain.
for those of you with desktopdyno, I'd be curious to know what it says my HP is and also if it says the cervini ram air hood make a difference.
looking forward you your thoughts.
Also, as soon as my msd6BTM box gets back from msd I'll put the blower on and head for the track. hoping for mid high 14's.
Best,
__________________
Delray
94 F150 Supercab Flareside, 5.8, 3.73's, gt40 heads, BBK headers, Basani Y-pipe, Vortech S-Trim, Cervini Ram Air, Lowered 2/4
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 07-02-2008, 12:39 PM
Conanski's Avatar
Conanski has a good reputation on FTE.Conanski has a good reputation on FTE.Conanski has a good reputation on FTE.
Yeah.. 50hp is more than reasonable from better heads and a free flowing exhaust. You are nowhere close to realizing the full potential of the heads with the stock truck cam, the 5.8 will still produce good TQ with a 270 deg cam, a blower cam like the Comp 35-351-8 would certainly help get the most out of it, that motor could make over 300hp before forced induction.
__________________
Paul O
1990 F150 4x4 XLT X-Cab 5.0, 3.55, Comp 35-349-8, Flowtech LT's to 3" single, FRPP Mass Air Conversion
Under construction: '85 351HO, Dart Iron Eagles, Roller Rockers, Typhoon intake, Crane 444232, 24lb Injectors, TweecerRT, Innovate LC-1 wideband O2
1990 Ranger 2wd, 2.3 Briggs & Stratten, 5-speed, 3.08 gears, sliding rear window.
  #3 (permalink)
Old 07-02-2008, 12:47 PM
yep. I know, i should have did the cam while i was in there, but the cam and related components would have pushed me over $3K and my CFO would have had an absolute fit. all in due time.
oh I for got to mention, my mpg in town jumped from 12 to 14.6. I'll take it on a business trip from Columbus to Indianapolis on the 15th and see if the hwy mpg is also up 2-3 mpg. hoping for 16-17 mpg.
__________________
Delray
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
