Go Back   Ford Truck Enthusiasts Forums > Misc. > Air Intakes, Air Filters and Ram Air
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 07-02-2008, 11:29 AM
12engine's Avatar
12engine 12engine is offline
12engine is gaining momentum as a positive member of FTE.
intake for 94 f150 4.9l?
hi all,
i have a 94 f150 with the 4.9 300 I6. what is the best aftermarket intake to get? K&N's filter kit is $235+- and only gets like a 5 hp increase. thats $47 a HP. thats too much. any help would be awesome.
  #2 (permalink)
Old 07-19-2008, 06:25 PM
FTE Ken's Avatar
FTE Ken FTE Ken is offline
Founder ... Stay Tuned
FTE Ken has a superb reputation FTE Ken has a superb reputation FTE Ken has a superb reputation FTE Ken has a superb reputation FTE Ken has a superb reputation FTE Ken has a superb reputation FTE Ken has a superb reputation FTE Ken has a superb reputation FTE Ken has a superb reputation FTE Ken has a superb reputation FTE Ken has a superb reputation
You're pretty much left with few choices. There generally aren't many aftermarket performance choies for the 300.
__________________
-Ken
If you need to get in touch with me email me at ftsservice at gmail dot com or via AOL IM: motorhavenken.
The best is yet to come....
  #3 (permalink)
Old 07-28-2008, 07:09 PM
ReAX's Avatar
ReAX ReAX is offline
2002 Ford F-250
ReAX has a great reputation on FTE. ReAX has a great reputation on FTE. ReAX has a great reputation on FTE. ReAX has a great reputation on FTE. ReAX has a great reputation on FTE. ReAX has a great reputation on FTE.
That kit and some exhaust work was worth every penny on my old truck. I didn't ever get around to building a heat shield for, but it is something you should consider.
__________________
Too many mods to list, so click here.
Here are my tech write ups
Look, see these two tow hooks? They look like tusks. And what kind of animal has tusks?
  #4 (permalink)
Old 08-03-2008, 01:57 PM
rikard rikard is offline
rikard is starting off with a positive reputation.
I would spend my money on the exhaust. The stock CAI isn't that restrictive. You can buy a K&N drop in for the stock filter box. My 2 cents.
rikard
__________________
Present-1995 Black F150 SC XLT 300 5 Spd
Past-1994 Red F150 SB XL 300 5 Spd
1983 Red F150 SB XL 302 AOD
1962 USPS 2.5 ton stepvan converted camper
223 3 speed DRW
1956 Red F100 Ma Bell uility bed 223 3 Spd
  #5 (permalink)
Old 08-03-2008, 02:51 PM
ReAX's Avatar
2002 Ford F-250
Maybe my 89 was different, but the air box only had a 1"x5" hole to breath through. The surface area of the hole was nothing compared to the stock filter.
__________________
  #6 (permalink)
Old 08-03-2008, 11:02 PM
FTE Ken's Avatar
One of the easiest things you can do for a little added power is get air intake temps down. That's not just about bringing cold air in, its also about keeping it as cold as possible before it reaches the engine.
For example, with the outside temps about 95 degrees with the hood open and the engine fully warmed my Roush supercharger datalogs IAT's around 120-130 degrees. If I point an infrared sensor at the filter box its temperature is about 110 - 115 degrees at the furthest point from the engine and nearly 140 degrees at the throttle body. I wrapped the Roush intake tube and the air box with thermal wrap (the kind used to insulate firewalls from heat and sound). IAT's from this dropped any where from 10 - 15 degrees depending on how long the engine is running. Moving the wrap aside and aiming the sensor at the tube shows a corresponding 10 - 20 degree drop in the tube temperature. It's a simple and very inexpensive way to add a little power without using more fuel. It looks ugly as hell but it works well.
__________________
-Ken
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
