Biodiesel Roll Call - Page 9 - Ford Truck Enthusiasts Forums
View Poll Results: Alternative Diesel Fuel Usage
I make and use Biodiesel 56 19.44%
I would like to make biodiesel 134 46.53%
I use straight veggie oil 40 13.89%
I use Waste motor oil 21 7.29%
I use a blend 34 11.81%
I purchase retail biodiesel 72 25.00%
Multiple Choice Poll. Voters: 288. You may not vote on this poll
Biodiesel Roll Call
  #121
Old 08-09-2012, 03:12 PM
rooster 07 F250 rooster 07 F250 is offline
rooster 07 F250 is starting off with a positive reputation.
I have a few local restaurants that currently have the waste oil picked up and they have expressed that they would give it to me, but I have not nailed down these options completely. We r talking about 25-30 gals. per wk max.
I really appreciate the insight and advice.
  #122
Old 08-10-2012, 07:50 AM
Rushmore X's Avatar
Rushmore X Rushmore X is offline
Rushmore X has much to be proud ofRushmore X has much to be proud ofRushmore X has much to be proud ofRushmore X has much to be proud ofRushmore X has much to be proud ofRushmore X has much to be proud ofRushmore X has much to be proud ofRushmore X has much to be proud ofRushmore X has much to be proud of
Welcome to the forum!
  #123
Old 08-10-2012, 11:04 AM
flainn's Avatar
flainn flainn is offline
flainn has a very good reputation on FTE.flainn has a very good reputation on FTE.flainn has a very good reputation on FTE.
Lock it up quick, preferably with something in writing. Good oil sources are very hard to come by these days, and the business is cutthroat.
  #124
Old 08-10-2012, 02:03 PM
Good advice thanks
  #125
Old 11-13-2012, 11:38 PM
BoxedDuk BoxedDuk is offline
BoxedDuk is starting off with a positive reputation.
I just recently purchased an E-450 box truck that "i want to convert" to run on svo so my vote would be for "svo"
  #126
Old 06-13-2013, 05:32 PM
zedd77 zedd77 is offline
zedd77 is starting off with a positive reputation.
Smile veggie oil
I do a mix of used veggie oil/diesel/gasoline/and injector cleaner. I have been using the mixture for over 100,000 miles. I have a '95 F 250 w/7.3 in it. It now has 310,000 + miles on it. I actually get more power and better mileage when I run it. If you want to quiet your engine a little - feed it a quart of new veggie oil in the tank. I cannot recommend this in a 6.0 however. I have one of those too. But I was cautioned against using it. I was told a 10% mixture would be OK but I think the 6.0's are too touchy.
  #127
Old 06-19-2013, 09:55 PM
idiabuse idiabuse is offline
idiabuse is gaining momentum as a positive member of FTE.
I have been running motor oil blended with old stale boat gas when I find it.
I actually mix everything together that happens to be a petroleum product.
Atf, Hydraulic oil, engine oil, diesel oil, gear oil, transformer oil.
I mix in 5 gallons of RUG to 50 gallons WMO and filter it all through a mess of filters and a 10GPM filter cart for final pass. I always add fuel additive around 16 ounces per 55g drum
Down to 10 microns.
Have over 20,000 miles on it runs just fine, no smoke out the tailpipe.
Javier
  #128
Old 12-12-2014, 12:01 PM
TheCurtster's Avatar
TheCurtster TheCurtster is offline
TheCurtster has a good reputation on FTE.TheCurtster has a good reputation on FTE.TheCurtster has a good reputation on FTE.
Noob help?
Hi gang,
Doing my homework... Trying to decide if I ought to buy a bio processor from a guy I met. Other than the reliable source of oil, it looks like I'll need a supply of methanol too.
Does anyone have a good source in the Southern California area? Preferably LA or Ventura counties... Heck, preferably next door, but maybe that's asking a bit much. With shipping, I've been quoted $425 for a 55 gallon barrel, and that starts to make the whole thing unattractive.
Thanks!
Curt
  #129
Old 12-12-2014, 12:18 PM
binuya's Avatar
binuya binuya is online now
binuya has a great reputation on FTE.binuya has a great reputation on FTE.binuya has a great reputation on FTE.binuya has a great reputation on FTE.binuya has a great reputation on FTE.binuya has a great reputation on FTE.
Quote:
Originally Posted by TheCurtster View Post
Hi gang,
Thanks!
Curt
Finding methanol should be the easy part. If pricing is anywhere close to what I pay here, expect around $200 for a drum. A quick google search found Los Angeles California Chemical Distributor - Wholesale Bulk Fine Chemical Supplier - Westco Chemicals Inc in north hollywood, but I'm sure there are others there in that area. Personally, I don't think you should underestimate the ease of finding WVO. You wouldn't want to invest your time, money, and space with everything else to find you can't obtain feedstock. Procuring, setting up, collecting, and pre-treating WVO is actually the most labor intensive and time consuming part of the process of making biodiesel. I would see if you can set up your WVO accounts first, before making the commitment. Good luck!
  #130
Old 12-12-2014, 12:55 PM
Fett Affen's Avatar
Fett Affen Fett Affen is offline
Fett Affen is starting off with a positive reputation.
methanol source
I live in the Inland Empire and I get my methanol from Merit Oil. Last I paid was about $250.00 plus the drum charge. You are also going to need a source for KOH. That is what I have been using for the last 3 years since I have been making it. What kind of price were you quoted on that?
  #131
Old 12-12-2014, 03:12 PM
Here's a source for NaOH:
$105 for 50 lbs, shipped
50 lb Pail of Sodium Hydroxide [50drhdl] | DudaDiesel Biodiesel Supplies
Not sure if that's crazy or not. 50 lbs oughtta make quite a bit of product.
They also sell KOH:
45 lb Pail of Potassium Hydroxide [45drhdp] | DudaDiesel Biodiesel Supplies
A little more, but I hear that KOH is a better way to go.
Not ready to jump in just yet, as I still have not secured my oil source. Lots of small restaurants around though. Hopefully something will work out.
Thanks for the info,
Curt
  #132
Old 12-12-2014, 05:31 PM
Rushmore X's Avatar
Get my Methanol from the local guy who supplies parts for dirt track racing. Runs about 23 bucks for 5 gallons. I use KOH myself which I buy in 25 kg bags off the Internet. I repackage it into gallon zip lock bags to make it easier to use and measure. Tried NaOH once. Glycerin is thicker and harder to work with.
Another thing to consider is how you are going to dispose of the glycerol...
  #133
Old 12-13-2014, 03:42 PM
Tom D Tom D is offline
Tom D is starting off with a positive reputation.
Hi gang,
Thanks!
Curt
Curt
I get my methanol from a team of race car drivers who use it for their fuel. I pay $200 a barrel. I get my KOH from Duda Diesel. Last batch was $107 plus $22.81 shipping. Been making bio for about 6 1/2 years now thanks to Fabman and others on the net. Don't be afraid to offer the restaurant a little bit for their oil. I started free but had to pay .50 a gallon to compete with the collection company. Still a good bargain. Ends up costing me $1.25 a gallon to produce. (I don't capture the methanol) Good luck.
Tom D.
  #134
Old 12-13-2014, 08:46 PM
Best price on the methanol (so. Cal) so far is $300 OTD for 55 gallons, plus a $25 barrel deposit. Makes the cost per gallon worthwhile I think. Still trying to nail down the oil supply. I like the idea of paying 50 cents a gallon, if I can get it in the jugs. The oil dumps are friggin nasty.
Curt
  #135
Old 12-13-2014, 10:17 PM
binuya's Avatar
Something you might want to keep in mind as you're planning WVO accounts is that every restaurant handles their used oil differently. Some dump it directly into a vessel that you provide, i.e. 55 gallon drum, or metal dumpster, which you will need to either lift and replace, or pump out regularly. Some will dump the cooled oil back into the cubies they came in so you can easily come by and just pick them up.
Additionally, some will dump their oil with all the cleaning water and chunks along with it. Whichever method each restaurant employs, you need to be prepared to deal with whatever it is they give you. That means a system to course filter and de-water the WVO. It is also important to keep the area where this exchange is occurring, clean, neat, and tidy. Restaurants want hassle free service. That is likely the primary reason most restaurants will go with a large rendering company because they're equipped to do so. And, in most cases, it's not about the money because the tiny sum they're paid for the used oil doesn't amount to much.
I've found many restaurants would rather give the oil to a local individual than to a large company, as long as they can be assured everything I've already stated. Ask me how I know. In the 7 or so years I've been brewing biodiesel, I've never had to pay for WVO. It's about developing a relationship, making a personal connection, and taking care of business. I've taken away accounts from both large companies, and individuals like ourselves, who couldn't hold up their end of the deal. They either made a huge mess, or couldn't pick up the WVO when the restaurant needed it picked up. Once you establish yourself with a reputation for being professional, on time, clean, and hassle free, finding used oil will not be an issue. It's a commitment, but once you get your ducks in a row, it's an easy, worthwhile hobby.
castor oil for bio? jamusfam Bio-diesel, Propane & Alternative Diesel Engine Fuels 1 08-18-2014 08:30 AM
Bio fuel ? Curt's05 6.0L Power Stroke Diesel 41 08-01-2014 02:30 PM
Bio Diesel/Oil Selection Olds69442 6.7L Power Stroke Diesel 6 07-25-2012 09:30 PM
Bio-diesel FL450 Bio-diesel, Propane & Alternative Diesel Engine Fuels 18 05-13-2008 09:06 AM
obtaining cooking oil for bio diesel badass truck Bio-diesel, Propane & Alternative Diesel Engine Fuels 4 04-22-2008 04:17 PM
Tags
1988, 2000, 2004, 2005, 2008, 73, b99, bio, biodiesel, conversioin, diesel, f250, f350, ford, idi
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
