1991 302 Manifold Plug Size
Old 06-24-2008, 07:38 AM
WesternAuto17's Avatar
WesternAuto17
WesternAuto17 is offline
Hey guys, I've done some searching, but I found nothing.
There is a plug in the rear of the left exhaust manifold on my 1991 F150 302. This little guy decided yesterday to strike out on his own and leave me and the rest of the truck behind. Does anyone know what size this thing was?
Thanks in advance --
Old 06-24-2008, 04:18 PM
EPNCSU2006's Avatar
EPNCSU2006
EPNCSU2006 is offline
If it's a standard O2 sensor bung, it will be 18 x 1.5 mm, and you'll need an O2 sensor block-off plug since it is not a tapered thread. I'm not sure that the hole you have is for that unless it's a replacement exhaust manifold that will fit a newer truck too.
Old 06-24-2008, 04:21 PM
WesternAuto17
It is a replacement manifold. Do you know where I can get one of these plugs? I am having zero luck finding one.
Thanks for the answer.
Old 06-24-2008, 06:45 PM
alz's Avatar
alz
alz is offline
Here is what a little internet searching pulled up.
O2 Bungs & Plugs, 02 bung Plug, RPS-o2plug | RacePartSolutions.com
Not sure if you could find this locally. Probably a race shop would have them.
Old 07-02-2008, 07:06 AM
WesternAuto17
"Bung" was the magic word missing from my searches. Thanks for the help.
As an update, NAPA has a metric oil plug that worked great. It is part number BK7041037.
Good times.
Dirty Offio
10-18-2015 07:09 PM
Da_Lariat_Chariot
02-11-2015 01:44 PM
SVTDriver97
13
06-03-2014 07:40 PM
Valdez904
04-30-2013 05:53 PM
FilmGuy
10-21-2005 04:26 PM
Quick Reply: 1991 302 Manifold Plug Size
