2003 4.6l v8 - stalling at low idle or coast - Ford Truck Enthusiasts Forums
Old 07-01-2008, 10:16 PM
mheglin mheglin is offline
mheglin is starting off with a positive reputation.
74,000 miles and just started stalling after vehicle warms up. Will even get a surge. Can keep running by increased gas. Just recharged AC myself??? Could that have caused. Also makes noise like metal hitting on empty can.
Thought could be egr valve or fuel fillter? Where do i start? Thanks
Old 07-01-2008, 10:29 PM
BJWinter BJWinter is offline
BJWinter is starting off with a positive reputation.
Is this in park or when you are in gear?
Old 07-02-2008, 07:39 AM
While driving. It will stall coasting to a stoplight or behind traffic. Hate to take to dealership knowing they will guess like I am. I will take to autozone today and see if it is showing any codes. Any other suggestions?? Thanks
Old 07-02-2008, 07:52 AM
I started having a similar problem with my 2000 4.0L OHV about a month ago. The body on the crankshaft position sensor had gotten cracked and water would get in there every time I hit a puddle or went through the carwash. I can't remember which code it woudl throw when that happened, but I will try to look it up. This is a $20 part and about 30 minutes of cussing to fix.
I also had a similar problem with my 1997 F150 4.6L. Turned out that the torque converter lockup solenoid had gone bad. As I slowed down, the engine would start to bog and finally die just as I can to a stop. I could keep it running by revving the engine. In this case, I wasn't throwing any codes at all. If your check engine light isn't on, you might consider this. The local transmission shop fixed it for about $200 and I never had another problem with the transmission (the engine blew, but the tranny was SOLID!).
Old 07-02-2008, 10:49 AM
My problem sounds more like the tranny issue you indicated. I am not getting check engine so i question whether will get any codes.
I am also being told to look at the egr valve..
Old 07-02-2008, 02:59 PM
Checked codes and nothing. Did the tranny place diagnois the problem or did you before taking in.
Old 07-02-2008, 06:57 PM
Someone on here suggested that was the problem, so I had it towed to Aamco and they confirmed. At that time they offered free diagnostics, but I'm not sure if they still do.
I guess I just don't understand how the problem could be EGR related if you're not getting any codes at all. Between my F150 and my Explorere I've had plenty of EGR problems, and every one of them has set a code for some part of the system.
Old 07-03-2008, 11:33 PM
mrjones111 mrjones111 is offline
mrjones111 is starting off with a positive reputation.
Sounds like classic idle air control motor symptoms. The noise wouldn't be related to the IAC motor.
Old 07-07-2008, 04:56 PM
Any tests I can do for the idle air. It doesnt start stalling until it warms up. It only drops down to 500rpms or stall a couple times then it idles alright. Had codes checked again and nothing. Thanks for any help.
Old 04-05-2010, 12:42 PM
silvermaxd silvermaxd is offline
silvermaxd is starting off with a positive reputation.
Quote:
any updates on the noise?
Stalling and hard start 1987 F250 6.9L RBerry9511 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 2 07-24-2014 01:03 PM
Starts then stalls -- Ford E350 7.5L facets 1968-2013 Full Size Vans 15 03-06-2014 03:09 AM
06 van just stalls thunderbird1986 1968-2013 Full Size Vans 3 10-21-2013 08:24 AM
Truck stalled while driving and now it cranks but won't start exc4x4 Excursion - King of SUVs 6 04-09-2011 11:06 PM
Expedition won't stay running... timrec Expedition & Navigator 3 11-12-2006 04:25 PM
Tags
1995, 1997, 2003, 46, 46l, explorer, f150, ford, gear, idle, low, mountaineer, stall, stalls, surge, v8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
