Go Back   Ford Truck Enthusiasts Forums > Misc. > Cooling, Heating, Ventilation & A/C
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Cooling, Heating, Ventilation & A/C SPONSORED BY:
Click Here
  #1 (permalink)
Old 10-29-2002, 05:48 PM
dfiske dfiske is offline
Garage is empty, add now
dfiske is starting off with a positive reputation.
blower motor resistor
I know this has been covered about a thousand times before but I can't seem to understand where the resistor is. My blower only works on the high position and I've read where it's the blower motor resistor but I can't seem to find the resistor. I'm slow so type slow so I understand! :P
Thanks guys.........
  #2 (permalink)
Old 10-29-2002, 06:31 PM
kioolt kioolt is online now
kioolt is starting off with a positive reputation.
T h e b l o w e r motor resistor is located under the hood on some vehichles and inside the passenger compartment on other vehicles. No matter which location it is it will always be in the air flow of the blower itself (the blower will blow air over it). It will have four wires on it and if I remember correctly is mounted with two screws.
__________________
95 Taurus GL
94 Mark VIII
93 F150XLT
  #3 (permalink)
Old 10-29-2002, 06:34 PM
Thanks, I'll check it out tomorrow in the daylight. I have a 96 f150 sc 4x4 with the 5.8liter. I really appreciate it.........
  #4 (permalink)
Old 12-02-2002, 07:36 PM
Steve_Uzi Steve_Uzi is offline
Steve_Uzi is starting off with a positive reputation.
Look under the hood, generally the wiring for the Blower resistor is attached to the wiring to the blower motor itself.
__________________
-CraZy Steve
"To Conquer is to Live"
  #5 (permalink)
Old 12-03-2002, 09:56 PM
steve83's Avatar
steve83 steve83 is offline
steve83 is starting off with a positive reputation.
It's inboard & below the motor, near the accumulator. You can see it standing beside the passenger fender. You can almost see it in pic #41 ('93 5.8L right.JPG) in this album, but it's the off-white connector behind the L heater hose above the vacuum reservoir & the white WARNING sticker:
http://www.webphotos.com/list_photos.asp?mi=3&smi=1&a=66912
__________________
Walk softly & carry a BIG 6!
  #6 (permalink)
Old 12-05-2002, 07:53 PM
mathelm's Avatar
mathelm mathelm is offline
mathelm is starting off with a positive reputation.
And it's called a "reostat"
  #7 (permalink)
Old 12-05-2002, 08:00 PM
I'm going to have to disagree with it being a rheostat. A rheostat is an adjustable resistor. The heater blower resistor is a multi tap resistor.
__________________
95 Taurus GL
94 Mark VIII
93 F150XLT
  #8 (permalink)
Old 12-05-2002, 09:18 PM
steve83's Avatar
Right. A rheostat is a wound variable resistor, where most other potentiometers use a continuous film of resistance material. The heater resistor is actually a pack of 3 high-current resistors (in the form of coils of resistor wire) and a thermal fuse.
__________________
  #9 (permalink)
Old 12-13-2002, 09:50 PM
mathelm's Avatar
OK, what it "realy" is, is a "SPEED CONTROL". But for all practical pusposes, its a "REOSTAT". I personaly had rather refer to it as "that heater thingamagig".
  #10 (permalink)
Old 12-13-2002, 11:31 PM
nitro94's Avatar
nitro94 nitro94 is offline
nitro94 is starting off with a positive reputation.
RESISTOR- A devise used in an electric circuit to producd work or to lower the voltage in a circuit. RHEOSTAT- A resistor for regulating a current by means of variable resistances. Sometimes called a potentiometer or "POT."
__________________
Lynn
  #11 (permalink)
Old 12-15-2002, 08:46 AM
mathelm's Avatar
Webster don't work in a garage. There they call engines "motors" and they call a blower motor speed control a "reostat"...
"Don't listen to what I say, Listen to what I mean"
  #12 (permalink)
Old 12-15-2002, 08:54 AM
I don't work for Webster. I have been repairing, installing, and troubleshooting electric and electronic circuits for about 30 years. The blower motor resistor is NOT a rHeostat. A rHeostat is a variable resistor. The blower motor resistor has fixed taps on it that give stepped blower control. The resistor itself is not the controlling device. The controlling device is the **** on the dash.
__________________
95 Taurus GL
94 Mark VIII
93 F150XLT
  #13 (permalink)
Old 12-15-2002, 09:08 AM
mathelm's Avatar
Your not at all **** either are ya. If I told you I needed a "reostat" for my car would I get 30min lecture on resistor component theory?
Don't correct my engish, spelling or terminolgy. If I'm talkin to you, and you don't understand me, feel free to ask. If you want to teach electronics, do it in a classroom. With you guys around, who needs heat.
  #14 (permalink)
Old 12-15-2002, 12:25 PM
steve83's Avatar
A) If you told him you needed a "reostat", he'd probably give you a "rheostat" for the dash light dimmer inside the headlight switch since he knows what a rheostat is.
B) If you were in a technical forum and used the wrong term, yes, you would be corrected. If you want to spread disinformation without being corrected, start your own website called "Mye_oppinyuns_abut_ evverting.com" and say whatever you want using whatever spelling you think is right. This BBS is here to help people by giving them correct information, including terminology, and the language most often used here seems to be English, whose words already have spellings so there's no need to add confusion by creating your own spelling for words that already exist. Wenn du Deutsch schreiben moechtest, koennten wir uns auch unterhalten, aber bitte, keine Vertippungen.
C) It appears he DID understand you, but the next person to read this thread might not if you use the wrong terms, spell them wrong, or use another language.
D) This forum IS a good place to teach electronics as they relate to Ford 12V HVAC. That's why it exists.
E) It takes 2 to tango, and you're continuing to use terms you know are wrong just as much as he is (& I am) continuing to correct you, so you're generating just as much "heat" as we are.
__________________
  #15 (permalink)
Old 12-15-2002, 01:50 PM
Thank you Steve.
__________________
95 Taurus GL
94 Mark VIII
93 F150XLT
Tags
2000, 2001, 4l5z19a706aa, 95, blower, control, e450, electronic, f150, f250, fan, ford, motor, rangerwhere, resistor, speed
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
