Removing AC compressor - serpentene belt length - Ford Truck Enthusiasts Forums
Old 12-03-2002, 10:49 PM
steve83's Avatar
steve83 steve83 is offline
steve83 is starting off with a positive reputation.
Old 12-08-2002, 03:11 AM
quasar314 quasar314 is offline
quasar314 is starting off with a positive reputation.
My 1989 F150 302 AC compressor is history. Removed it and I wanted to know do I need to install a idler pulley in place of the AC comp. or can I just use a smaller serpentene belt? Does anyone sell a kit to replace the AC compressor with a plain old pully?
Old 12-08-2002, 11:56 AM
steve83's Avatar
You'd have to look at where the belt will lie if it runs straight - it might rub something & wear out instantly. I'd advise just unplugging the clutch & leaving the compressor attached to the engine. It's gotta be the cheapest idler kit you'll find.
Old 12-15-2002, 10:08 PM
rebocardo rebocardo is offline
rebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud of
You should be able to use it without the A/C. I would hit a junkyard (or used car lot) and find one without A/C and look at the decal under the hood for the proper routing. If at a junkyard, I would take the decal.
Then just order the "without A/C" belt from a parts store. If by chance that does not fit correctly, buy one of those emergency belts that snap/hook together. Then remove and measure it.
Make sure the tensioner is in good shape.
Old 12-16-2002, 01:26 PM
bumpin_BII bumpin_BII is offline
bumpin_BII is starting off with a positive reputation.
ya unhook the compressor. if the clutch is locked pull it out. or then again instead of buying that belt take a pieces of thin rope and run through your pullys minus the a/c and messure its lenth. and your done....
Old 12-19-2002, 12:12 AM
Thanks!:-)
Old 12-19-2002, 12:16 AM
[updated:LAST EDITED ON 19-Dec-02 AT 00:16 AM (EST)]Thanks for all the suggestions, I ended up just eliminating the comp.altogether and going with a smaller belt. It took a couple of trips to auto parts store but a shorter belt works fine!
Old 02-11-2003, 04:53 PM
randallc's Avatar
randallc randallc is offline
randallc is starting off with a positive reputation.
What belt was it? I am removing my A/C from my 1990 F-150 and will probably try to use a new belt if I can. If you tell me what size your belt was I may have a a good start on it.
BTW: I have a 351W EFI is your engine the same size? or are you running a 302?
**** bradphx 1973 - 1979 F-100 & Larger F-Series Trucks 59 12-05-2016 04:27 PM
ooops Aerostar 5 01-14-2015 04:16 AM
... miko6810 Modular V10 (6.8l) 9 06-04-2014 07:14 AM
Tailgate mods 1978 - 1996 Big Bronco 6 05-25-2002 04:08 PM
Cams broom FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 8 11-24-2001 01:46 PM
Tags
302, 351w, ac, belt, compressor, eliminating, explorer, f250, ford, length, remove, sport, trac, truck, wo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
