Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > Expedition & Navigator
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Expedition & Navigator 1997 - 2002 and 2003 - 2006 models
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 07-01-2008, 04:47 PM
pgonza2723 is starting off with a positive reputation.
Exclamation Need help with a/c fan speed
So recently the a/c in our truck seems to be stuck in the highest fan speed setting. Changes from either the steering wheel controls or the panel control do nothing to change the speed. When I try to turn the system to off completely it will go to what I believe is the vents and stay on full blast. I've ready on earlier years (98-99) that this problems mainly resides in the:
Blower motor resistor
MOTORCRAFT Part # YH1699 {#4L3Z19A706AA}
w/4 Pin Connector
but since ours has the dual zone a/c I'm not 100% sure since there is also:
Blower motor speed controller
YF3Z19E624AA
One is like $15 and the other is $130 so looking for thoughts before taking the plunge. Also, where is the blower motor resistor for an 2006 Expedition with the dual zone? I know where the blower motor speed controller is but not sure what to look for with the resistor. Thanks for any help!
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 07-01-2008, 06:03 PM
projectSHO89 has a good reputation on FTE.projectSHO89 has a good reputation on FTE.
You have either the resistor or the controller, not both.
The speed controller is used with the EATC, the resistor is used with a blower speed switch.
Steve
__________________
Think about it: Ignorance can be addressed through education but you can't fix stupid! ...apologies to Ron White
  #3 (permalink)
Old 07-01-2008, 06:28 PM
Thanks for clearing that up! It's the answer I was looking for, not it was also the answer I wasn't hoping for . Ah well, at least it's easy to get to instead of being a $500 fix. Oh btw, does the diagnosis sound accurate I assume? Anything else it "could" be?
  #4 (permalink)
Old 07-01-2008, 09:57 PM
It might be the control head, but the BSC is the most likely.
Steve
__________________
  #5 (permalink)
Old 07-01-2008, 11:29 PM
Thanks for all the help .....
  #6 (permalink)
Old 07-02-2008, 07:43 PM
For future reference if it's needed by other peeps, the part number for the blower speed module is 6L1Z-19E624-A and it's located on the passenger side downstream from the fan. There is a physical connector between the two so it's hard to miss. Took all of 10 upside down minutes to replace and $40. Thanks again for the help Steve.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
