Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 06-30-2008, 09:44 PM
mind's Avatar
mind is starting off with a positive reputation.
Gauges Installed.
Just put them in. It does look nice, bought the kit from ITP Diesel and it came with everything I needed, came out pretty good. I just had to share.
Now I'm waiting on the Bellowed Up Pipes that are on backorder!
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 06-30-2008, 09:50 PM
big poppa pump's Avatar
LOW RIDE RRR>>>>>>>>>>
big poppa pump has a great reputation on FTE.big poppa pump has a great reputation on FTE.big poppa pump has a great reputation on FTE.big poppa pump has a great reputation on FTE.big poppa pump has a great reputation on FTE.big poppa pump has a great reputation on FTE.
Looks great, thing for me to do next. Congrats on the install. Just wondering, since your waiting for the up pipes, where did you put the temp pyro probe?
__________________
Mike 2003 f-250 XLT CC 7.3 SB, auto, 4x4 373,s S-B air intake w snorkel,DP Tuner-NS,Stock,60T,80E,120R,140A, WW, CCV mod, SC Codereader, Isspros 3 pillar, foil del, MBRP 4 in duals, 285 Yoko,s A-T, Bilsteins, 2in shackle kit (Thanks Zack7.3), Zdad, CrimeStopper Alarm w remote start, Cobra 29 cb dual firesticks. PAA MEMBER 26#
  #3 (permalink)
Old 06-30-2008, 10:08 PM
megawatt00's Avatar
Jaymi-Lyn says be a......
megawatt00 is a splendid one to beholdmegawatt00 is a splendid one to beholdmegawatt00 is a splendid one to beholdmegawatt00 is a splendid one to beholdmegawatt00 is a splendid one to beholdmegawatt00 is a splendid one to beholdmegawatt00 is a splendid one to behold
Nice clean install.
__________________
Jim
2001 F350 4X4 DRW
Bilsteins, 4" Turbo Back MBRP
6637 w/ Custom Cold Air Intake
Guages Next
PAA#14
Rick,Will ,JD, What Are We gonna DoNow?
  #4 (permalink)
Old 06-30-2008, 10:13 PM
clux's Avatar
ain't wrapped tight
clux is a splendid one to beholdclux is a splendid one to beholdclux is a splendid one to beholdclux is a splendid one to beholdclux is a splendid one to beholdclux is a splendid one to beholdclux is a splendid one to behold
that's the same guages as I have, just in a different order. looks good.
__________________
2000 F350 cc lariat 4wd 7.3l
1991 Bronco xlt 5.8l
known 6637 basher
  #5 (permalink)
Old 06-30-2008, 10:25 PM
BioHazrdMan's Avatar
BioHazrdMan is gaining momentum as a positive member of FTE.
Looks great! That is next on my list I think.
__________________
NOAH
  #6 (permalink)
Old 06-30-2008, 10:30 PM
mind's Avatar
Pyro is not installed yet, waiting till I do the up pipes so when i drill i can stick the vacumm in the manifold and get the shavings out.
  #7 (permalink)
Old 06-30-2008, 10:47 PM
hucka1a's Avatar
Just Trying to Learn
hucka1a has a good reputation on FTE.hucka1a has a good reputation on FTE.
Good Job. Gauges are on my long list of to-do's. Like an idiot, I let my gauges and my chip go with my OBS.
__________________
Huck
early 99 (11/24/98)
F250, PSD, 4x4, auto, ec, short bed.
PAA Member 66
6637/wrapped by Pete, CCV Mod, Autometer Ultralites, 6.0 Trans Cooler, MKO 4",'05 Power Seats
  #8 (permalink)
superduty4x4's Avatar
superduty4x4 has a great reputation on FTE.superduty4x4 has a great reputation on FTE.superduty4x4 has a great reputation on FTE.superduty4x4 has a great reputation on FTE.
Just put your pyro probe in the manifold, and don't worry about the shavings- they aren't going to hurt anything so long as you take your time, start small, and work your way up.
__________________
Chase
1999 F250 XLT C/C Shorty 4x4 PSD
2000 Explorer XLT 4x4 (wife's)
1992 Tempo GL- deer basher. Score: Tempo-2, Deer-0
PAA Member #2!
ThumperTalk
All Things Moto!
  #9 (permalink)
Old 06-30-2008, 11:04 PM
Quote:
Alot of guys put the probe in the up-pipe before the turbo, called pre-turbo. I was thinking of doing that, whats your thoughts?
__________________
  #10 (permalink)
Old 06-30-2008, 11:24 PM
mind's Avatar
I mean I was gonna put mine on the manifold right before the up pipe, but since I have to do the up pipes anyways I was just gonna wait till I did them. I've heard its better to put it pre-turbo but I'm weary of drilling and tapping the manifold as it is...
  #11 (permalink)
Old 06-30-2008, 11:37 PM
Izzy351's Avatar
Master Debater
Izzy351 has a great reputation on FTE.Izzy351 has a great reputation on FTE.Izzy351 has a great reputation on FTE.Izzy351 has a great reputation on FTE.Izzy351 has a great reputation on FTE.
Take your time and use several drill bits. When you tap, you might practice on some scrap metal first to get the feel for it before you do the real thing. You go in a little, then back out. Add more tap oil, go in a little further, back out. Keep going until you've got it in far enough. It's not difficult, but does take a certain "touch".
Oh and when I did mine, I just drilled, tapped, and installed. There won't be that many shavings in the exhaust, and the few that are will blow out though the turbo without hurting anything.
__________________
  #12 (permalink)
Old 07-01-2008, 12:01 AM
Tenn01PSD350's Avatar
Miller Brewing Co
Tenn01PSD350 has a great reputation on FTE.Tenn01PSD350 has a great reputation on FTE.Tenn01PSD350 has a great reputation on FTE.Tenn01PSD350 has a great reputation on FTE.Tenn01PSD350 has a great reputation on FTE.Tenn01PSD350 has a great reputation on FTE.
I drilled and tapped my up pipe several years ago and that is where it still is. No problems as of yet. I blew any shavings out the exhaust. The good thing about this is if you botch it, a simple clamp will repair the oopsie, but it is highly unlikely unless you tap too far.
__________________
2001 350 4X4 AUTO, GTP38R, Swamps Hybrids, DPTuner live tuned, PMRs
399.99/789.54
Mike
  #13 (permalink)
Old 07-01-2008, 12:08 AM
I,m following you Mike,lol. As for the gauges, any of you go with the insulated probes?
__________________
  #14 (permalink)
Old 07-01-2008, 03:58 AM
Either the manifold or the up-pipe work fine for a pyro install. DO NOT put it in the downpipe- your EGT's will read low and you risk melting your motor down.
Since the OP is doing up pipes anyways, he may as well wait and drill/tap the up pipe on the bench unless he's in a big hurry to get the pyro working. As for you big poppa pump, pick your favorite spot and do as I or Joe said- just drill and tap, don't worry about the shavings. I didn't use any grease or oil on the tap when I did mine. The up pipe will probably be a lot easier to drill for you than the manifold.
__________________
Chase
PAA Member #2!
ThumperTalk
All Things Moto!
  #15 (permalink)
Old 07-01-2008, 08:41 AM
Ponyboychris's Avatar
Ponyboychris has a good reputation on FTE.Ponyboychris has a good reputation on FTE.Ponyboychris has a good reputation on FTE.
Nice install. Just like the other said, if you drill using a few drill bits and step up, you will not have shavings problems.
BTW, nice Baja VW in the garage.
__________________
Chris
2002 F350 XLT, 7.3L CC 4x4, LWB, SRW, Autometer Ultralites, DP TUNER, BTS Trans, 6.0 tranny cooler, AIS w/zoodad, Warn Hubs, 4" MBRP exhaust, '08 rear end cover, Foil Delete, Heated Tow Mirrors, Go's Headlight Harness, AIH Delete.
The Silver Bullitt
Quote:
Originally Posted by Smokin' View Post
I prefer to leave touchy-feely in the bedroom.
PAA# 24
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
