Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1980 - 1986 F100, F150 And Larger F-Series Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 06-30-2008, 09:11 PM
RAMBOv10 is starting off with a positive reputation.
Motorcraft starter
I posted this in the 87 up forum but since the starter is more like the 80 to 86 I thought I would post here also. Has anyone tried the MotorCraft starters at AdvanceAuto? I am working on my uncle's 1989 F-250 with a 351. It has the dreaded hard to crank problem when hot. I have cleaned all the ground and checked for a voltage drop and have pretty much determined that it is the starter. I can go to a dealer and get one, but since I have already bought one starter at Advance I can get a Motorcraft there and just have to pay the difference from the other starter.
Thanks, Daniel
__________________
Daniel
2003 F-250 V10 Sport CC 4X4 Long Bed
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 06-30-2008, 09:44 PM
jason85351's Avatar
jason85351 is starting off with a positive reputation.
If it's cranking hard i would go with a high torque starter they run around 150 bucks but well worth it.
__________________
1985 Ford F150 351w 4x4 lift 35" BFG Mud Terrains
Finally Finished driving the truck again till november then putting her in storage
  #3 (permalink)
Old 07-01-2008, 07:01 PM
It only cranks slow after it gets hot, when it is cold it cranks over just fine. Where are the high torgue starters sold?
__________________
Daniel
  #4 (permalink)
Old 07-01-2008, 07:19 PM
jason85351's Avatar
The high torque starters can be found in summit or jegs it should help it when the engine is hot. Does it have long tube headers?
__________________
  #5 (permalink)
Old 07-01-2008, 08:10 PM
Piffery1 is gaining momentum as a positive member of FTE.
I've never had problems on stock engines with standard starters (that were in good condition). Only times I ever needed high torque starters was on engines with increased compression ratios.
First thing I'd do is load test the battery with everything at normal operating temperature. Use a tester with at least 100 A. draw, 500 A. is better.
  #6 (permalink)
Old 07-01-2008, 09:25 PM
Franklin2's Avatar
Franklin2 has a great reputation on FTE.Franklin2 has a great reputation on FTE.Franklin2 has a great reputation on FTE.Franklin2 has a great reputation on FTE.Franklin2 has a great reputation on FTE.
Has anyone checked the timing? It looks like it's fuel injected, but someone could still monkey with the timing and get it too far advanced if they did not know the procedure on how to set it.
I just worked on a fuel injected vehicle that ran ok, but pinged when hot. I checked the timing and it was 16 degrees off. The poor old computer was trying to pull it back where it belonged, but 16 was just too much for it.
__________________
Dave F
1989 F250 XLT Diesel
  #7 (permalink)
Old 09-28-2008, 02:32 PM
Thumbs up
Just to let anyone know if this happens to them. After trying two starters at advance auto, cleaning grounds and checking cables I finally put a motorcraft starter on and it solved all my problems. Truck starts great everytime cold or hot.
__________________
Daniel
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
