Go Back   Ford Truck Enthusiasts Forums > Diesel > 2003 - 2007 6.0L Power Stroke Diesel
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
2003 - 2007 6.0L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 06-30-2008, 08:37 PM
Baddfx4 is starting off with a positive reputation.
EGR valve/Thrttle plate removal questions
I have a 2003 F-350 with a 6.0L with 6-speed tranny, I looked at the earlier threads about disconnecting the EGR valve and it says something about the throttle plate that I have on top of the engine, I looked at the plug-ins and there is no prongs sticking out of the "so-called sensors" on the plate so basically there is nothing there, and I took the elbow off to see if there is a plate and there is none there. What can I do to remove this plate so I can get rid of this junk and try to let the air flow better, perhaps installing a power elbow for a 2005/2006 models? Will this do me any good or am I wasting my $$$$ and I am thinking about getting rid of the EGR valve also and I looked into getting the delete kit from ITP Diesel. Any suggestions? Thanks
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 06-30-2008, 11:36 PM
william_04_x's Avatar
william_04_x is gaining momentum as a positive member of FTE.
if the TP is already gone, don't worry about it...if it's in there, don't worry much more..a new intake elbow(unless you have a really strong engine) won't show much benefit either...save the $$$ for something else..
egr(cooler) delete can save you some grief and expense in the future..
what is your goal? performance, reliability, increased mileage?
that's right...all of the above...
__________________
04 EB X w/03 6.0l PSD
Southern Nevada Power Strokes.Org
  #3 (permalink)
Old 07-01-2008, 05:28 AM
satcom40's Avatar
satcom40 is starting off with a positive reputation.
I install the new elbow it looks better then the factory.
__________________
04 F-250 SD 6.0L XLT EC SB Black, May 04 build. Bypass filter for Oil & Coolant, Remote start, Pre-Post Luber, Scan Gauge, 46 gal fuel tank, Boost & Pyro.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
