Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Other Ford Engines > Flathead V8 and Flathead 6
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 06-30-2008, 06:29 PM
41inWV's Avatar
41inWV 41inWV is offline
41inWV is gaining momentum as a positive member of FTE.
Learn from *MY* mistakes......
My 1941 1/2 Ton pickup need the old 221 rebuilt, so we took it apart....bored it to 239, replaced the cam with a geared '48-'53 cam so we could run an MSD Electronic ignition, swapped out the crank pulley for a double sheave pulley, of yeah, converted to 12 volts, so put an extended pulley on the altenator up top. All this went along just fine, then came the water pump issue. I technically need a pair of '37-'48 'Bg Truck' water pumps with the double sheave pulleys so the fan belt would be properly aligned, but those are rare and expensive when you DO find them. So, I took a pair of '48-'53 regular truck pumps which have the extended pulley shaft.....they work PERFECTLY.....until....and this is the my MISTAKE part, I filled it with water and antifreeze..........fluid CASCADING down the front of my nice new engine......
In 1949, ford added a water passage opening in the TOP of the water pumps....I did not KNOW that.....I recovered though......1/2" freeze plug added to each water pump and we're good to go
__________________
Steve
http://www.wvgoldenoldies.com/images/duo1.jpg
WV Chapter Member
1941 Ford 1/2 Ton Flathead - FTE 'Ride of the Week' 10/28-11/02 2008
1934 Chebby Sedan
  #2 (permalink)
Old 07-03-2008, 04:00 PM
petey shoes petey shoes is offline
petey shoes is starting off with a positive reputation.
steve, thank god it was external and not in the engine! thanks for the tip.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
