Go Back   Ford Truck Enthusiasts Forums > Diesel > 1994.5 - 1997 7.3L Power Stroke Diesel
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 06-30-2008, 04:32 PM
woodsy188's Avatar
woodsy188 is starting off with a positive reputation.
Glow Plug Relay Stays On
Just got finished replacing the under valve cover wiring harness and two burnt plugs. Put it back together, started it up, and the glow plug relay started to smoke. I put a test light on the relay and it didn't turn off. Thought I needed a new relay, but the new unit does the same thing. I'm worried that if I run it too long I'll burn up all my new wiring. fficeffice" /> > >
I would think that it’s the glow plug controller, but I read somewhere that the glow plugs in this era Powerstroke are controlled by the PCM. > >
Any ideas? > >
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 06-30-2008, 05:06 PM
Hussler's Avatar
Hussler is starting off with a positive reputation.
Yes glow plug relay on time is controlled by the PCM. What year truck do you have? On my 97 if I disconnect the small PPL/ORG wire on the relay (it goes to the PCM) then the relay should not activate. The PCM grounds that wire. Look for maybe a short on that wire enroute to the PCM.
__________________
Jim
1997 F250 HD CC 4x4 7.3L - E4OD - 3.55's
EVBP Disconnected - Napa 6637 - FPR Shim
3" Down Pipe & CD - 302 Stat - 159 K Miles
The only thing I pull is the extension cord to my truck.
  #3 (permalink)
Old 06-30-2008, 05:17 PM
woodsy188's Avatar
This is a '95 F-350. The smaller wires on the relay are both red, go into a plug, and come out (1) pink and (1) red (with green stripe) on the other side of the plug. The wires quickly disappear into the covered wire harness.
Where is the PCM? Is it the silver metal box under the hood near the fuse box on the drivers side? Or is it under the dash where you plug in a code reader?
  #4 (permalink)
Old 06-30-2008, 05:24 PM
Action4478's Avatar
taH ssA
Action4478 has a good reputation on FTE.Action4478 has a good reputation on FTE.
It may be the wrong relay ,,,It needs to be an isolated ground unit,,meaning the case isn't grounded ,the PCM adds the ground when called for ...
You should be able to test the on time from the ground wire from the PCM with a test light...
__________________
Rick.....
97 F 350 ...Lucky 13
"Most stuff's just stuck & needs hittin with a hammer"....
Supporter/End user of ShiftSolutions THE CURE E4/4R Trans Control. Helping Cancer patients and families
www.fordtransmissioncure.com
Special thanks to RacerX www.racerxautomotive.com
  #5 (permalink)
Old 06-30-2008, 05:32 PM
Hussler's Avatar
The Red(with green stripe) is the +12 volts (always hot) and the other is the wire going to the PCM. Check where the harness(s) goes across the drive side valve cover for rub through and possible damage.
PCM is located in the area you mentioned but so is the IDM. I don't have a picture of it but somebody will probably post one.
You should have +12 volts on both your smaller Red wires on the Glow Plug Relay for the relay to be OFF. To be ON one of the Red wires will be at ground (via the PCM).
__________________
Jim
  #6 (permalink)
Old 06-30-2008, 05:34 PM
Hussler's Avatar
Good point .. what Relay did you purchase ??
__________________
Jim
  #7 (permalink)
Old 06-30-2008, 05:36 PM
woodsy188's Avatar
For what its worth, I replaced it with the same relay that has been on the rig. I'd say its not grounded through the base. The metal base is riveted to the plastic case of the relay. I checked to be sure by touching the base to the neg battery post and put the test light on the pos battery post, then touched the tester to all the posts on the relay - didn't light the tester, didn't complete a circuit... not grounded through base.
  #8 (permalink)
Old 06-30-2008, 05:39 PM
woodsy188's Avatar
The new relay is a NAPA ECHLIN part #GPR111
  #9 (permalink)
Old 06-30-2008, 05:54 PM
woodsy188's Avatar
I turn the key on. One of the small posts has 12+ volts. The other has .5 volts. (Doesn't turn a test light on). By what you said, that indicates relay is on. I didn't see any obious signs of wear on the wire harness across the valve cover.
I'm stumped.
  #10 (permalink)
Old 06-30-2008, 06:29 PM
Action4478's Avatar
taH ssA
NAPA GPR 109 Or 110 is what you should have ...never hear of 111...
__________________
Rick.....
  #11 (permalink)
Old 06-30-2008, 07:10 PM
tjbeggs's Avatar
tjbeggs has a very good reputation on FTE.tjbeggs has a very good reputation on FTE.tjbeggs has a very good reputation on FTE.
Does the relay stay on longer than 2 minutes? Just verifing that we actually have a problem. I second Action on 111. The 110 is what our trucks take.
__________________
Tim
Proud User of "The Cure"
1997 F-350 PSD Auto 257K
Tuned by Tony, Built by ME!
TDP/TW tunes
AD injectors
6.0 IC
17* HPOP
Tru-cool
The Cure
ESE Eliminator
6" stacks
4 Wh disc brakes
1/4 mile-14.59@88 MPH
Click the Picture for wiring diagrams, tech info and Pictures!
  #12 (permalink)
Old 07-01-2008, 10:38 AM
woodsy188's Avatar
TJBEGGS- I guess I was over worried! I timed it and the GPR shut off @ 65 seconds. The relay on my '92 cycles so fast that I was worried about burning up wiring on the '95. Sorry for all the commotion about nothing - thanks for the advice!
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
