Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Diesel > 2003 - 2007 6.0L Power Stroke Diesel
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
2003 - 2007 6.0L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 06-30-2008, 09:54 AM
crmarshall is starting off with a positive reputation.
First big tow.
I just got back from my first trip towing my new Toy Hauler. All loaded up I was pulling approx 8,000lbs. The truck handled the load very well but the EGT's were getting really high. My probe is located on the drivers side manifold and I run a Autometer NV gauge. When pulling a long hill the temp was topping out at 1250 or so. I hear the pistons melt at that temp so I started backing down. As soon as I let off the throttle the temp would drop to 1000 and stay there. It also ran around 1000 pulling on the flats. Is this safe? I have no chip and the boost gauge never read above 20#. Thanks in advance for any info.
__________________
[/SIGPIC]
2005 F250 Crewcab XLT Lariat FX4 6.0 PSD
4" tough country lift.
4" exhaust with Banks muffler.
35" Toyo O/C on 18" wheels.
AFE cold air intake.
Firestone Airbags with compressor.
Turbo Liner
Auto Meter NV EGT gauge.
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 06-30-2008, 10:05 AM
brickie's Avatar
brickie is starting off with a positive reputation.
She will run all day long at 1250. The truck will de-fuel stock if the motor gets to hot.
__________________
08/03 build 2004 350 Crew DRW 6 speed XLT fx4, EconoMax injectors, Autometer Fuel, Boost & EGT. AFE filter, Sct X-III, EGR delete, ARP studs, RR fuel system, Southbend FB8, Fluiddamper, Ali Arc hunting bumper, Ride-Rite helpers.
  #3 (permalink)
Old 06-30-2008, 05:22 PM
bigredtruckmi's Avatar
Farmer and proud of it
bigredtruckmi is gaining momentum as a positive member of FTE.bigredtruckmi is gaining momentum as a positive member of FTE.
Watch your coolant temp for problems. Yes the EGT's are important but is just your first indicator of a hard pull.
__________________
red 04 F250 build date 04/04 6.0 PSD ,auto,cc, xlt ,sb, moon roof, 4X4, off road pkg, sports pkg., tow pkg,camper pkg,FX4, electric shift on fly
93 f350 7.3 , 5 speed manual, ext cab, long box 240K+ miles
1967 C700 farm truck
30 ft travel trailer
Vietnam Vet/ OS1 USN/USNR retired 26 years
B5 soydiesel user
Sirius radio
  #4 (permalink)
Old 06-30-2008, 05:54 PM
UGA33's Avatar
Yeah Come On!
UGA33 is gaining momentum as a positive member of FTE.
1250 is when you just need to start paying attention. Like brickie said, she'll be ok.
__________________
2006 F-250 Lariat Crew Cab Shortbed FX4
-Josh-
*6.0L PSD*MBRP Turbo-back*35" BFG Mud Terr. KM2's*Leveling Kit w/ Daystar Coil Spacers & Rancho RS5000's*Spartanized SCT X3*Autometer EGT & Tranny guages*Coolant Filter*CCV Reroute*F-350 blocks*High Idle Mod
  #5 (permalink)
Old 06-30-2008, 10:03 PM
blong2107 is starting off with a positive reputation.
whats up guys haven't been on here in awhile been too busy jus curious the post read first big tow whats the most you guys have pulled thought it'd be an interestin question
__________________
04' F350 Lariat 6.0 PSD CC LB 4x4 dually
-SCT XCal III w/ custom tuning
-K&N Intake
-EGR delete
-Throttle Plate delete
-4" Straight Pipe... no kitty here
-Next: 05 front end and leveling kit
  #6 (permalink)
Old 07-01-2008, 07:09 AM
UGA33's Avatar
Yeah Come On!
14k for me
__________________
-Josh-
  #7 (permalink)
Old 07-01-2008, 08:20 AM
saftman is starting off with a positive reputation.
38' fifth wheel; 13,000# all day long.
  #8 (permalink)
Old 07-01-2008, 09:11 AM
Mustangbru8 is starting off with a positive reputation.
only 10k for me
  #9 (permalink)
Old 07-01-2008, 09:27 AM
utahtom's Avatar
utahtom is gaining momentum as a positive member of FTE.utahtom is gaining momentum as a positive member of FTE.
Hope the original poster doesn't mind the direction of his thread...
I pulled through the weigh station 10 days ago with my weights listed as:
Front axle: 5,020 lbs
Rear axle: 4,960 lbs
Trailer axles: 13,560 lbs
The truck is nearly perfect 50/50 weight distribution... Although I didn't have much fuel or water- I put in about 800 lbs of fuel and 200 lbs of water before launching!
__________________
06 Tow Boss F350 DRW/4.30 CC Lariat LB FX4 TS 4X4 6.0PSD
Truth is confrontational: There is no 1 ton Dodge/Cummins or GM/Duramax rated to legally tow what I pull
6.0 Grin Since 2/26/03
Utah Chapter Leader
  #10 (permalink)
Old 07-01-2008, 01:56 PM
Sounds like I should be just fine pullin my little bitty trailer. You guys are pulling some serious weight. Good to know I don't have to chew the rest of my fingernails off watching the gauge next weekend!
Hey Tom, good to see another Utah poster. I'm just down in UT county.
__________________
[/SIGPIC]
Turbo Liner
  #11 (permalink)
Old 07-01-2008, 05:27 PM
firesoutmatt's Avatar
firesoutmatt is starting off with a positive reputation.
40' fiver with toybox 18k stickers says but I know it's a wee bit over that.
__________________
05 F-250 CC SRW LB 4x4 6.0 Tow Command Lariat Remote Start All Stock 01 Alfa 40' Toyhouse for all the toys.
I'm doing my part to reduce our dependency on foreign oil and clean up the environment; my truck runs on 100% biodiesel made from soybean oil grown by U.S. farmers. What are you doing?
  #12 (permalink)
Old 07-01-2008, 09:11 PM
the most i've pulled is 25k and it pulled it like a champ
__________________
-K&N Intake
-EGR delete
  #13 (permalink)
Old 07-01-2008, 09:43 PM
Bulldog66 is starting off with a positive reputation.
14k Toy Hauler w/gear.
350 cc lwb 3.73 lariat.
Never needed tow/haul save hill climbs.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
