Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Excursion - King of SUVs
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 06-30-2008, 01:41 AM
mtford is starting off with a positive reputation.
Dash Problems!!!
My 02' EX has 127k on it and other than a climate control issue has been great. I'm running a super chip programer on it and yesterday pulled my boat with it set in the "hi performance" mode which is a no no I no. Didn't think about it till almost to the lake. Had been driving moderately and became even more so once I figured it out. As I'm driving I see the oil press. guage reading below zero. Shut it down. Check the oil (OK). Figured If it had no press. would have quite running on own due to injectors would stop firing fuel? Left the lake and oil press. guage pegs over High mark. Because of the extreem placement of needle I was wonder if a short could cause it? Then today pulling boat again the check engine light comes on. I checked codes and only found the common 1000 and 1250 or something like that. Restarted truck and engine light is out!!??!?!? Any ideas? Could they be related?? Maybe a failing dash cluster??
__________________
1960 f100 4x4 all orig. --2000 f350 Lariate PSD 4x4 crew,super chip programer, 6637 ,minor lift ,air tank system with bags and horns
--2002 Excursion Limited PSD 4x4,6637, super chip programmer, minnor lift.
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 06-30-2008, 03:14 AM
Monsta's Avatar
Sit. Stay. Become a
Monsta is a name known to allMonsta is a name known to allMonsta is a name known to allMonsta is a name known to allMonsta is a name known to allMonsta is a name known to all
Does it do when you put the truck back to stock tune?
__________________
Ken
05V10
I love cats.
...but I can't eat a whole one.
  #3 (permalink)
Old 06-30-2008, 11:07 PM
Since I put it to tow performance nothing incorrect has happened but it may be too early to tell. I've only put on about 20 miles in the tow performance mode (still pulling the same boat).
__________________
  #4 (permalink)
Old 07-06-2008, 10:30 AM
changed it back to stock and ck engine light still off but op guage still reading below off possition and sometimes above high possition. Changed the programmer to tow performance mode and same thing. Thinking ops is bad, wiring harness has a short, and/or dash cluster/guage problem. My chiltons shows ops on top/back of block near bell housing on an addapter. can anyone verify? got on top and underneith with a light and can't see anything, not even a wire going in that area. called local parts store and sensor (if they had a listing) varied from $15-$80. Haven't called the dealer yet.
__________________
  #5 (permalink)
Old 07-06-2008, 11:57 AM
Monsta's Avatar
Sit. Stay. Become a
Maybe looking in the 7.3L forum will yield results for the location of the sending unit. Or even starting a new thread.
I don't know where it is personally.
__________________
Ken
05V10
I love cats.
  #6 (permalink)
Old 07-06-2008, 10:48 PM
Thanks. I'll give it a try
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
