Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Misc. > Aftermarket Products
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 06-29-2008, 10:39 PM
mike L is starting off with a positive reputation.
aftermarket cruise control
Any one every added one in a compact car? How hard is it? I'm looking at adding the kit with a small box the sticks to the dash.
__________________
1993 F-150 5.0 4x4
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 06-30-2008, 08:40 PM
ReAX's Avatar
Molon Labe
ReAX is gaining momentum as a positive member of FTE.ReAX is gaining momentum as a positive member of FTE.
It all depends on how it works. Most newer vehicles have a VSS (Vehicle Speed Sensor) that means you don't have to add magnets to the drive shaft or tap any vacuum lines. Then the actuator it the other difficult part, you will need to mount the actuator to the fender or top of the motor, then attach the linkage to the throttle body. Hopefully the TB already has a stud to tie to.
After those little problem areas it's just mounting the brain and the controls, and running a few wires. Some vehicle have everything in place but the controls, unfortunately the body control module has to be reprogrammed to make it work.
__________________
Too many mods to list, so click here.
-MECP 06/27/08
Look, see these two tow hooks? They look like tusks. And what kind of animal has tusks?
there's a very fine line between not listening, and not caring. I like to think that I walk that line every day of my life.
  #3 (permalink)
Old 07-01-2008, 06:44 AM
reprogrammed
" the body control module has to be reprogrammed to make it work."
Does it have to be reprogrammed for each car? If I installed the cruise control mayself where can I go to have it reprogrammed?
thanks
__________________
1993 F-150 5.0 4x4
  #4 (permalink)
Old 07-01-2008, 09:05 AM
MisterCMK's Avatar
MisterCMK is a splendid one to beholdMisterCMK is a splendid one to beholdMisterCMK is a splendid one to beholdMisterCMK is a splendid one to beholdMisterCMK is a splendid one to beholdMisterCMK is a splendid one to beholdMisterCMK is a splendid one to behold
I installed an Audiovox (I think) cruise control in my 92 Escort many moons ago. It was a simple matter of mounting the actuator, supplying vacuum, installing the cable and hooking up the small switch unit inside the car. No reprogramming of anything needed. I think that what ReAX is talking about is adding a factory cruise control to a vehicle that didn't come with it. I added an aftermarket unit.
__________________
Chris
1994 Mustang GT
1992 Explorer XLT
2000 Expedition EB
Quote:
Originally Posted by tcbofade
I have no brain
  #5 (permalink)
Old 07-01-2008, 10:48 AM
Aftermarket kit is what i'm looking for, with no programming. thanks. Dealer whats 400.00 installed.
Where did you find your aftermarket unit?
__________________
1993 F-150 5.0 4x4
  #6 (permalink)
Old 07-01-2008, 10:29 PM
ReAX's Avatar
Molon Labe
Audiovox and rostra are both pretty good. On vehicles with a VSS, I'd find a VSS cruise kit so you are using a constant speed and only need to pick up the VSS wire for speed sense.
Right, the reprogramming is something that has to happen if you want to activate the factory cruise. Some vehicles come with the throttle body actuator factory installed, but they don't put in the controls. For those, you add the factory switches and most need to be flashed to accept those controls. Straight aftermarket is speed sense, power and throttlebody control.
__________________
-MECP 06/27/08
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
