Go Back   Ford Truck Enthusiasts Forums > Misc. > Electrical Systems/Wiring
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 06-29-2008, 09:13 PM
barrypeterson is starting off with a positive reputation.
Windows & radio don't work
This happened suddenly; None of the windows work from either door, the radio/clock also are dead, although I can eject the CDs.
Both fuses are good but they don't have power to them.
Could it be a wire from ignition switch to fuses? Are there any other things to check? A/C, seats, headlights, and dash lights work.
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 06-29-2008, 09:18 PM
megawatt00's Avatar
Jaymi-Lyn says be a......
megawatt00 is a splendid one to beholdmegawatt00 is a splendid one to beholdmegawatt00 is a splendid one to beholdmegawatt00 is a splendid one to beholdmegawatt00 is a splendid one to beholdmegawatt00 is a splendid one to beholdmegawatt00 is a splendid one to behold
What year make and model is your truck. I may be able to find a diagram for you.
BTW Wekcome to FTE!!
__________________
Jim
2001 F350 4X4 DRW
Bilsteins, 4" Turbo Back MBRP
6637 w/ Custom Cold Air Intake
Guages Next
PAA#14
Rick,Will ,JD, What Are We gonna DoNow?
  #3 (permalink)
Old 06-29-2008, 09:27 PM
Thanks, it's a 2002 F-350 DRW CC, we're grateful that the A/C still works!
  #4 (permalink)
Old 06-29-2008, 09:33 PM
megawatt00's Avatar
I can't get it to post, to large. Do you want me to send it via email?
__________________
Jim
2001 F350 4X4 DRW
Guages Next
PAA#14
  #5 (permalink)
Old 06-29-2008, 09:40 PM
Gas or diesel Barry?
It's diesel, 7.3L but I doubt that matters.
  #6 (permalink)
Old 06-29-2008, 09:41 PM
megawatt00's Avatar
No I just checked and there both the same.
__________________
Jim
2001 F350 4X4 DRW
Guages Next
PAA#14
  #7 (permalink)
Old 06-29-2008, 10:30 PM
Franklin2's Avatar
Franklin2 has a great reputation on FTE.Franklin2 has a great reputation on FTE.Franklin2 has a great reputation on FTE.Franklin2 has a great reputation on FTE.Franklin2 has a great reputation on FTE.
Check fuse #41, 10 amp in the underdash fuse box. Are you sure everything else works? I am thinking you might have a accessory delay relay or circuit problem. This is what lets things work for a little while after you turn the key off.
__________________
Dave F
1989 F250 XLT Diesel
  #8 (permalink)
Old 06-30-2008, 12:03 AM
Quote:
#41 was blown! The owners book calls it accessory cluster or something like that. I used the Fog Lamp (10 amp) fuse but that blew instantly.
SO, I went to Wal-Mart. They have a spot for 10 amp fuses but it's empty. (Murphy's Law?)
BUT, they did have a miscellaneous set, which I bought. It has ONE each of 2, 5, 7½, 10, 15, 20, 25, and 30.
I replaced the Fog Lamp fuse with the 10, then tried the 15 in #41. That fixed the problem, the windows work and the radio/CD player works but I'm a bit leery of using a higher-than-normal fuse.
What do you think? What does #41 feed? (The window fuse is 30 amp and the Radio Main is 20 amp)
ISTR that circuits are fused at twice the normal current. True?
Thanks a million.
  #9 (permalink)
Old 06-30-2008, 12:48 PM
Yes, please.
barry.peterson@gmail.com
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
