Air Conditioning
Air Conditioning
I tried doing a search but couldn't find my exact problem. I drove ten hours the other week from Maine back to New York and the AC started out fine and cold...then just stopped blowing cold after maybe 5 or 10 minutes. To say the least...it was a hot ten hour drive! I brought it to my mechanic that week to have it checked out and on my way there it blew cold again. He put a little over a pound of refrigerant with dye in and it blew cold the whole way home. I took it out again this weekend and same thing...started cold then turned hot. Anyone have any ideas? I don't have any refrigerant gauges so if anyone thinks that could be the problem i'd have to bring it back to my mechanic. Any of your genious insight would be helpful. Thanks!
Just what I had to do. I cleaned the connections with that electric sprayer stuff in a can (can't think of the name) and no problems since then.
not to hi jack your thread but i have an ac problem where if im sitting idling or in stop and go traffic my ac gets warm, on the highway it blows cold and the engine temp doesn't rise at all to indicate the truck kicking it off to prevent overheating (don't know if these trucks do that or not but some vehicles iv had would automatically kick the ac off if the engine temp went above degree mark
So today i got a chance to pop the hood. I pulled the plug right by the pulley and cleaned it up and sprayed some electrical lubricant on it. I started the truck with the hood open to watch the compressor clutch with the AC on. It was running fine and cold then stopped. I went out and saw the the compressor clutch kept engaging and disengaging every five/ten seconds or so. Almost sounded like a hiss (maybe belt sliding?). Does that mean that my compressor is shot?
no, your friend might have overcharged it. The next plug back is the high pressure sensor, it might be causing it to kick out. Clean it like you did the plug next to the clutch. If it still acts up check your air gag like mentioned above. If it still acts up after all this you have to much refirgerant in there.
