Go Back   Ford Truck Enthusiasts Forums > Diesel > 2003 - 2007 6.0L Power Stroke Diesel
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
2003 - 2007 6.0L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 06-29-2008, 07:40 PM
F6Guy is starting off with a positive reputation.
what the F@#$
A good friend of mine just put his truck in the shop because his truck started smoking and lost all kinds of power. Ford repaired something with the EGR and replaced a head gasket. total cost $4400!!!!!! what in the hell costs so much. The truck only has 125000 miles and no power adders.
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 06-29-2008, 07:44 PM
Sarge261 is gaining momentum as a positive member of FTE.
The cab needs to come off to do the head gaskets. Couple that with the high labor rate costs and you get a high repair bill. I am sure that they replaced the EGR cooler as well. I am also quite certain that they repalced both head gaskets and quite possibly the head (s) as well. They have a very tight tolerance as to wether they can be machined down or not.
Maybe look at the bill and post what was done and someone will let you know if the price was fair. Also where are you located.
Sarge
__________________
2006 F-350 PSD Lariat Crew FX4 ALL BLACK
Banks Techni Cooler
Banks Big Mouth Intake Pipe
Banks High Ram Intake
Banks Monster Exhaust Turbo Back
BD Diesel Exhaust Brake
BD Diesel Torque Converter Pressure Controller
Air Ride Air Bags
Deep Sump Trans and Rear Diff. Pans
No-Shrink Tonneau Cover
  #3 (permalink)
Old 06-29-2008, 07:52 PM
dzldude's Avatar
dzldude is starting off with a positive reputation.
yea ford repairs can be damn expensive.my old 6.0 cost me 6200 dollars in repair bills 1 time.that was for egr replacment all 8 injectors a turbo and a body alighnment.so i sold and bought my new 6.4.
__________________
2008 F450 king ranch edition 6.4 PSD
2001 F250 platinum edition 7.3 PSD
1964 mack B-61
1986 F250 351 windsor
1986 F250 6.9 idi
  #4 (permalink)
Old 06-29-2008, 07:53 PM
tex25025's Avatar
tex25025 has a good reputation on FTE.tex25025 has a good reputation on FTE.
Quote:
Well there was a double whammy for your friend. Both problems are not cheap fixes on these trucks as they are pretty labor intensive(especially with head gasket repairs). Couple two expensive type of repairs for inflationary times(the hourly labor charge went from 75/hour(which is very competitive given the area that I live in) to 90/hour, glad I decided to do my own stuff(although that came about before the hike in hourly labor rate) and there you go.
__________________
'06 6.0L Turbo Diesel King Ranch DRW 4.30 Gears
Spartan Stage 1 Towing Injectors
Spartan 64mm Non-VGT Turbo
Fluidampner
Headstuds
Beta Spartan Phalanx
Fuel Regulated Return
FASS 150/180
5" Straight-Piped MBRP Exhaust
Tranny, EGT, Boost, and Fuel PSI C2 Gauges
Water Temp, Oil PSI, Volts Antique Beige Gauges
  #5 (permalink)
Old 06-29-2008, 07:55 PM
tex25025's Avatar
Quote:
I thought I read somewhere from one of the ford techs on here that the standard ford dictum is to just replace heads rather or not they could be machined?
__________________
Fluidampner
Headstuds
FASS 150/180
  #6 (permalink)
Old 06-29-2008, 07:58 PM
I think there is a debate on that as well. If I were doing the repair I would replace the heads. I have read on here that some are milling but with little or no success. I dont like to do the same job twice so its a simple decision for me.
Sarge
__________________
Banks Techni Cooler
Air Ride Air Bags
  #7 (permalink)
Old 06-29-2008, 08:02 PM
tex25025's Avatar
Well you can add one success story as I lucked out, although the machine shop that I went to has a wonderful reputation in the performance vehicle world down here in hickville.
__________________
Fluidampner
Headstuds
FASS 150/180
  #8 (permalink)
Old 06-29-2008, 08:07 PM
Well thats the other side of the coil Tex. When the heads get sent out if the machine shop does a poor job then I the tech in turn dont fixit right the first time. Never ending cycle.
I am glad it worked out for you though. Definatly a big savings if they can be milled and done right.
Sarge
__________________
Banks Techni Cooler
Air Ride Air Bags
  #9 (permalink)
Old 06-29-2008, 08:09 PM
tex25025's Avatar
I
Oh understand that 100% and I can definately understand where you stand on just replacing the heads.
__________________
Fluidampner
Headstuds
FASS 150/180
  #10 (permalink)
Old 06-30-2008, 10:59 PM
StealmyTruck is new and has a neutral reputation at this point.
Tell him to go get a 12v Cummins
  #11 (permalink)
Old 06-30-2008, 11:15 PM
FordF350Superduty's Avatar
FordF350Superduty is starting off with a positive reputation.
Maaan!!!$4400!!!Yes,I like Ford,but...with this a lot of problems...Cummins is best choice(just my opinion)
  #12 (permalink)
Old 07-01-2008, 11:21 AM
Benchwrench's Avatar
Benchwrench is gaining momentum as a positive member of FTE.
I'll take the 7.3 over the 12v any day!
  #13 (permalink)
Old 07-01-2008, 11:24 AM
Aside from the engine, I wouldn't want to be stuck with a dodge body, trans. or interior.
  #14 (permalink)
Old 07-01-2008, 03:34 PM
ozx3+1's Avatar
And the price is paid
ozx3+1 is gaining momentum as a positive member of FTE.ozx3+1 is gaining momentum as a positive member of FTE.
Quote:
Hickville? Isn't that just South of Backwater?
I thought I read somewhere... ...that ... ford dictum...
No, I don't think that ford dicked-um. It was a fair price
That will conclude the humor (from me) for today...
__________________
Brian
Torque is addictive
  #15 (permalink)
Old 07-01-2008, 03:48 PM
tex25025's Avatar
That hurts that you would pick on me like that. I guess that is what happens when all the love goes out of a relationship.
__________________
Fluidampner
Headstuds
FASS 150/180
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
