I have a short shaft 3 spd std trans that I think is out of a 71 f250 Can anyone confirm, deny, cajole, harass, or elucidate??
tag reads: rat Z 2 025781 I can email pics, but dont know how to have them hosted online for a link?!?! Thanks
On a standard 3 spd column shift, is the bellhousing an integral part of the tranny, like some of the automatics, or is it separate? I'm still considering putting a 302 in my truck, but i don't want to swap the entire tranny, mine was recently rebuilt, and it was a good heavy duty rebuild, so i'd like to keep it.
__________________
1974 Ford F-100, Straight 6, 3 speed on the Tree, 2wd. mostly stock....for now!
(10/6) NEwS flaSh: new clutch, new gear oil in the tranny.
thoughts on fixing daily drivers: work now, sleep later
The earlier, and possibly carried through along side the 303, BW box is non-synchro in first. This would be a side-loaded box.
The all synchro 303 was touted by Ford in some ads as a "3 1/2 speed" due to the all synchro. Having had a 303 and a top loader in my Mustang, I can tell you Ford's ad campaign was FOS.
(on edit--this box also had an OD unit available, an electrically shifted unit on the tail. I'm guessing, but the carry over of this box after the intro of the 303 was either for HD &/or for purposes of having the OD. Numberdummy would know for sure if he happens by....)
On edit, to clarify, the OP's box has "RAT---" on it, which id's it as a Ford 303 top loading 3 speed, not a BW. The top loader I refered to above in my Mustang was a WR 4 speed. I miss it so.
cool, thanks. ill remember that. how hard is it to find a 3 speed with OD?
__________________
__________________
