Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Modular V10 (6.8l)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 06-29-2008, 06:21 PM
10strokin is starting off with a positive reputation.
Smile computer codes wont read
hi all, in addition to my big v10, i also have an 89 f250 with a 460 in it. i know this question really doesnt belong in this forum, but i have been in here long enough to know that there are some extremely smart guys in here, so i will ask. anyway, the 460 just died on me this morning going down the road and wont start at all. it turns over fine. i put my ford code scanner on it and nothing will read at all. when i turn it on, it makes a couple relay noises but thats it. naturally i dont have a service manual for it because that's what the code reader book says. "if codes dont read, please refer to factory service manual for no codes troubleshooting". anyways guys, any help would be appreciated. thanks, matt. i have also posted on the big block 460 forum.
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 06-29-2008, 06:27 PM
Smile
and a lot of you guys might have used to have the 460 before you traded up to the big 10, so someone might have an idea? thanks again guys, matt
  #3 (permalink)
Old 06-30-2008, 11:00 AM
krewat's Avatar
krewat has much to be proud ofkrewat has much to be proud ofkrewat has much to be proud ofkrewat has much to be proud ofkrewat has much to be proud ofkrewat has much to be proud ofkrewat has much to be proud ofkrewat has much to be proud ofkrewat has much to be proud of
Check for power to the PCM - does the check-engine light come on when you first turn the key on?
Sounds like the PCM doesn't have power, or is otherwise hung up - is there a chip in/on it?
And, the big question, is the code reader going to work on an '89 Ford PCM?
__________________
- art k. - Moderator for the Superduty, V10, and FE forums
'01 F250SD SC SB XLT V10 4x4 auto 3.73 Volant CAI, eBay headers and y-pipe
'97 Cougar XR7 30th Anniv Edition 4.6L
'74 F250 Highboy FE390 deceased!
I've been wrong before, I'll be wrong again. Just wait and see.
  #4 (permalink)
Old 06-30-2008, 05:18 PM
the only light i see on on the dash is the battery light. it stays on. the code scanner i have works on all 87-96 ford f series with the 7.5 so it says on it. it is a ford code scanner. thanks art.
  #5 (permalink)
Old 07-01-2008, 12:21 PM
krewat's Avatar
Did you ever figure this out? The check-engine light should come on when you turn the key to ON. Unless the light's blown out, that means the PCM isn't getting power.
__________________
  #6 (permalink)
Old 07-01-2008, 05:45 PM
hey art. i think the light is blown out. but i do have power to pin 40 and pin 60 on the ecm. so whats next? i heard from someone to check a blue fusible link by the battery. does this sound right? matt
  #7 (permalink)
Old 07-01-2008, 09:56 PM
krewat's Avatar
I have no idea, Matt, just throwing it out there that if the light isn't lit, there's something missing power-wise. Pull the lamp, or, pull the connector to the PCM and put power to the light and see if it comes on - or hookup another light to the PCM directly. Or something.
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
