Wiper Delay Module - Ford Truck Enthusiasts Forums
Wiper Delay Module
Old 06-29-2008, 05:32 PM
LoneStarTrucker LoneStarTrucker is offline
LoneStarTrucker is starting off with a positive reputation.
Wiper Delay Module
I didnt' even know my 85 F-150 was even supposed to have intermittent wipers until someone told me I had a wiper delay module. I replaced the wiper switch and the intermittent part just goes at the same pace as the slow setting. Does this mean that the module is bad? And if so, where on earth can I get a new one.
Old 06-29-2008, 05:59 PM
81-F-150-Explorer 81-F-150-Explorer is offline
81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold
Quote:
Are you sure you are operating the switch correctly?
One click to the right, from off, slow speed. Two clicks to the right Fast.
Turn the **** to the left, all the way to the left is about 15 to 20 second pauses. All the way to the right of the intermittent section of the switch is 1/8 of a second pauses. Almost but not quite as fast as slow speed.
Wrecking yards are your best bet for a module, and switch.
1980-1991 F-series pickups.
1980-1998 F-series mid size trucks F-600 Up.
Old 06-29-2008, 06:17 PM
uncle.stosh uncle.stosh is offline
uncle.stosh has a good reputation on FTE.uncle.stosh has a good reputation on FTE.
The intermittent wiper switch is different from the 2 speed switch.
Junk yard is your friend. I have a couple extra sitting on the shelf right now.
Very nice to have and a very easy mod if you don't have delayed wipers.
Old 06-29-2008, 06:53 PM
ri_truck_guy's Avatar
ri_truck_guy ri_truck_guy is offline
ri_truck_guy has a great reputation on FTE.ri_truck_guy has a great reputation on FTE.ri_truck_guy has a great reputation on FTE.ri_truck_guy has a great reputation on FTE.
The post about your cruise conrol amplifier said it sounded like you were describing a wiper control box. Its possible you could have been describing the infered mileage sensor which is also in that same general area. If the wiper switch won't urn to the left you do not have intermittent wipers. But if you want the go to Ebay...they're always on there cheap. Its the easiest upgrade you can do on these trucks.
Old 06-29-2008, 08:46 PM
I always wondered why i could turn my **** to the left. It never did anything. I got a new switch and it now goes the same speed as the slow setting while turning to the right.
It looks like I'm off the the junk yard again. Wish I had known last week, I was there and probably passed by a few.
Old 06-30-2008, 07:36 AM
Look for an XLT truck or Bronco. They almost always had delayed wipers.
AFAIK all the way up to 96 are the same. Some modules are just tie wrapped to the harness near the switch, and some are held on with a metal bracket and one 8mm screw under the dash but they are all the same.
Old 06-30-2008, 08:30 AM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Wiper delay module 1984/91
E9TZ17B476A .. Intermittant Wiper Governor aka Module (Motorcraft SW2259)
E9TZ17B476A replaced: E7TZ17B476A & E4TZ17C476A.
Fits: 1984/91 F150/350 & Super Duty / 1984/91 Bronco (1992 and later is different).
MSRP: $121.47 / ftepartsguy.com price: $65.69
Old 06-30-2008, 10:21 AM
Quote:
Originally Posted by NumberDummy View Post
E9TZ17B476A .. Intermittant Wiper Governor aka Module (Motorcraft SW2259) E9TZ17B476A replaced: E7TZ17B476A & E4TZ17C476A. Fits: 1984/91 F150/350 & Super Duty / 1984/91 Bronco (1992 and later is different). MSRP: $121.47 / ftepartsguy.com price: $65.69
1980-1991 F-series and Bronco according to the motorcraft website.
Old 06-30-2008, 01:09 PM
Lazy K Lazy K is offline
Lazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to all
These modules usually fail because of breaks in the circuit. Pull it apart and solder any suspect joints or links.
Old 06-30-2008, 02:20 PM
Quote:
Yes, but the question involved a 1985, so I only posted the info that pertained to it.
When buying used parts, the governor for 1980/83 (E0TZ-17C476-A), won't work 1984/91 because the mounting plate is different.
The new replacing part fits all years, the original 1980/83 part will not.
Old 06-30-2008, 03:43 PM
True, but you really don't need the mounting plate any way.
Just make sure it's grounded and tie wrap it to the harness.
Old 06-30-2008, 04:08 PM
Failing that, you can take the mounting plate with you too, when visiting the wreckers. It's only held on there with a "screw-bolt" anyway.
Old 06-30-2008, 04:16 PM
The big Dummy hasn't examined one a these governors since Ford was prez, Gerald Ford that is.
So I can only go by what the parts catalog sez.
Old 06-30-2008, 09:41 PM
Thanks for all the input. I went and pulled 2 of these just incase 1 didn't work.
WTB: 1984 intermittent wipers Fummins WTB - Parts & other 1 01-20-2014 07:49 PM
Delay wipers again. 6t6merc 1961 - 1966 F-100 & Larger F-Series Trucks 5 06-23-2013 12:09 PM
Sparatic wiper delay 94 f150 turnkyle 1987 - 1996 F150 & Larger F-Series Trucks 5 12-31-2011 12:53 PM
Windshield Wiper Switch ZukBox II 1973 - 1979 F-100 & Larger F-Series Trucks 9 10-11-2010 04:01 AM
92 Aerostar Wiper Control is possessed!!! Rmcmorris Aerostar 4 02-22-2000 08:01 PM
Tags
2002, 2008, 83, 97, control, delay, f100, f150, f250, ford, fusion, governor, location, module, slow, wiper, wipers
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
