Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #16 (permalink)
Old 07-02-2008, 05:57 PM
GELGIN58 is starting off with a positive reputation.
Simple test to see if it's a vacuum leak.With it running spray some choke cleaner in the throttle body. If it smooths out you have a leak somewhere. My guess would be around the carb base gasket
Sponsored Links
To remove this ad, register today!
  #17 (permalink)
Old 07-02-2008, 06:35 PM
jack048307 is starting off with a positive reputation.
ok your were all right I had a vacuum leak. i changed the oil fill cap sealed the other side of the pcv system, got some vacuum caps. then i systematically unhooked and caped vacuum line until i discovered a hose that didnt affect the engine when i removed it. it was hooked to the choke pull off module. so it is caped off till i can get a replacement. after all this i was able to open the choke without stalling the engine. THANXS FOR STICKING WITH ME ON THIS. the choke pull of module i have on this carb is the same one that was in the carb that was put back on after the rebuild. the whole time it was bad.
  #18 (permalink)
Old 07-03-2008, 09:42 PM
just-n-time's Avatar
just-n-time is starting off with a positive reputation.
little things are a big pain at times, I was leaning towards a leak around the EGR valve, if you had one. JNT
  #19 (permalink)
Old 07-04-2008, 12:39 AM
nope 72 emissions simple easy
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
