Lots of smoke out exhaust - Ford Truck Enthusiasts Forums
Old 06-29-2008, 03:39 PM
Tom D Tom D is offline
Tom D is starting off with a positive reputation.
It seems like shortly after converting to 100% bio, my truck started smoking BLUE smoke at idle either in neutral or in gear. It does not clear up if I race the engine in neutral. It does APPEAR to clear up when I run it down the road (unless I just can't see it through the rear view mirror) The first time it did it, I filled the fuel filter with Diesel Kleen and it cleared right up for a few days. Now it's back. Any suggestions? I have original IP and injectors 167K miles. Thanks Tom
Old 07-02-2008, 11:19 AM
cookie88's Avatar
cookie88 cookie88 is offline
cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.
Pretty nice mods list. Did you turn up the IP any? Might just be time to have the injectors rebuilt.
Any other symptoms... hard starting, oil consumption, etc?
Old 07-02-2008, 07:42 PM
I believe you are right about the injectors. It idles pretty good and runs at cruising speed very well. I turned up the IP when I installed the Banks. I am installing "G" injectors this week. Thanks Tom
04 6.0L 2 stroke oil/Diesel Kleen in fuel mudsmokinstroker 6.0L Power Stroke Diesel 18 05-11-2014 05:26 PM
White smoke at start-up akamacgyver Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 7 04-04-2011 01:04 PM
White smoke + low coolant :( advice? dzzavid 1999 - 2003 7.3L Power Stroke Diesel 42 08-26-2009 12:48 PM
washed trucked and killed it fordman837000 1994.5 - 1997 7.3L Power Stroke Diesel 22 11-04-2008 10:23 AM
bad diesel fireeater91 1999 - 2003 7.3L Power Stroke Diesel 0 08-06-2005 01:35 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
