Quick stupid question!
Old 04-29-2001, 04:02 PM
bigcheese's Avatar
bigcheese
bigcheese is offline
Hey all -
I had my check engine light come on and it just stays lit up. How can I reset my check engine light as in get it to turn off? Any Ideas as to why it maybe on the truck runs fine maybe a bad senor or need to change something? But the point really is how would I get it to turn off period, thanks.
Old 04-29-2001, 07:52 PM
jim2000's Avatar
jim2000
jim2000 is offline
if your CEL is on then you might have an emissions problem you should be able to reset it by unhooking the battery but if the problem continues then the light will be back on.
Old 04-30-2001, 09:08 AM
predator1's Avatar
predator1
predator1 is offline
bigcheese unhooking the neg bat side is right but be sure you turn your headlites on at the same time for about 5 mins--this drains your computer capacitors, if it still lights up see the dealer. ours lite up at 48000 for our 50000 mile check up--nothing wrong just a little program to draw your interest.
2001 F-150 4X4 Supercab XLT 5.4L V8
139"WB 4sp auto 3.55 rear lim slip
trailer towing group- off road group
mods:
airaid fipk
superchip(flip)
roll-n-lock tonneau
Old 06-10-2001, 10:08 AM
greenschuz's Avatar
greenschuz
greenschuz is offline
Old 06-26-2001, 11:10 AM
JimCaudill's Avatar
JimCaudill
JimCaudill is offline
Yes, you can "clear" the codes by disconnecting the battery for 30 sec or so, and maybe turning on the light switch while the battery is disconnected is a good idea; but you will also lose the stored parameters your computer has learned to enable smooth engine operation for your engine. Your computer will have to relearn the specifics of your engine and drivetrain. No big deal really, just be aware that it will take a while. More importantly, the light is telling you that some component is malfunctioning. If the failure was a one time only affair, then the fault system will automatically reset after several driving cycles. If the light remains on over a period of time, then you failure is routine if not continuos. Get the code out of the computer and start looking for the problem.
Old 06-27-2001, 10:20 AM
robmc's Avatar
robmc
robmc is offline
Does anyone know how to pull the codes when your check enging light comes on?? I know how to on all the Toyota cars & trucks and I'm wondering if the Ford Trucks work in a similar fassion. Does Ford have your check engine light come on when you get close to 50k?
Alta
09-28-2013 04:22 PM
chrisginco
04-25-2013 04:36 AM
officer131
09-30-2012 12:09 PM
mdkid
1997 - 2003 F150
02-17-2011 02:31 AM
shmoney1
1997-2006 Expedition & Navigator
07-07-2004 06:29 AM
Quick Reply: Quick stupid question!
