DANG!!!
I think I just commited the cardinal sin of shade tree mechanics 101.
I used starting fluid and it would run on it until gone. I was about to go get a battery for my test light to check the fusible links out, when my wife came out to see if she could help me out. I said " Sure. Get in and crank it." She asked if she should hold the gas pedal down and I said "sure, we'll see if that helps." I sprayed more fluid into breather tube then told her to crank it. Well that's when things got CRAZY! It blew back into air filter box.
An M-80 couldn't have blown that box apart any better.
Pieces went everywhere! I'm lucky it didn't take my head off. I'm not worried about the filter box as they are cheap enough at the junk yard, but is it possible that I may have caused internal damage?
