Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Ranger & B-Series
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Ranger & B-Series
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 06-29-2008, 12:24 AM
ed-g35 is starting off with a positive reputation.
B2300 cam shaft position sensor-stuck screws
Need to replace the cam shaft position sensor on my 1994 B2300. When I tried to remove the screws, I found them to be firmly stuck. Had a similar problem when I replaced the DIS module and broke two of the three screws-don't want to do that again.
Anybody have any suggestions about how to get the screws out without breaking them?
Engine runs fine except there is a constant "Check Engine" light and continuous memory code of 214. It also will not run a KOER scan because the scanner cannot identify the engine as a 4 cylinder.
I have considered that it might be simpler if I could pick up the CID identification from the CKP sensor and connect it to pin 5 of the ECM. That should wire the truck as a 49 state legal instead of Calif legal. I think that would turn off the "check engine" light. Any thoughts on this or know for sure if this would work? Would that also make the KOER work again?
Thanks........Ed
Sponsored Links
To remove this ad, register today!
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
