Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1980 - 1986 F100, F150 And Larger F-Series Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 06-28-2008, 11:38 PM
Mnphil is starting off with a positive reputation.
Wheels to clear brakes
I would do a search but my comp is acting up. I have an 80 F-250 with the dual piston front calipers (2WD). Stock wheels are 16.5. Will 16" wheels clear the calipers? I truck is a hundred miles from me so I can't measure. Last I looked I know the dust shield would have to be trimmed. I want to run some narrow tires (either 215/85-16 or 235/85-16) for this winter up front.
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 07-03-2008, 11:33 PM
Anyone? Anyone at all? I can't drive the damn thing until I get a new setup. My other vehicle is going south fast so I need to get this truck up and running. One of the front wheels has a crack in the lip. All I need is a yes/no answer. Thanks.
  #3 (permalink)
Old 07-04-2008, 09:31 AM
Sycostang67's Avatar
Sycostang67 has a good reputation on FTE.Sycostang67 has a good reputation on FTE.
16" wheels should fit just fine. Ditching the 16.5" wheels for 16" wheels is a popular swap for most people since the 16.5 tires are in limited sizes and getting harder to come by.
__________________
1985 F-250HD XLT Lariat Supercab 4X4 460/5spd
2000 Ford Mustang-3.8/AT
2006 Jeep Liberty-3.7/AT
1967 Ford Mustang-351W/4spd
  #4 (permalink)
Old 07-04-2008, 10:19 AM
uncle.stosh's Avatar
uncle.stosh is gaining momentum as a positive member of FTE.uncle.stosh is gaining momentum as a positive member of FTE.
I'll take the 16.5's if you are ditching them.
16's will fit just fine.
Where are you located?
__________________
I live in the salvage yard.
Pennsylvania Chapter Member
  #5 (permalink)
Old 07-04-2008, 11:39 AM
That's great new- I don't like using 17's. I'm located in Minnesota. I'll keep the old ones for spares. Thanks for the offer though.
  #6 (permalink)
Old 07-04-2008, 03:52 PM
86F250BIGBLOCK is starting off with a positive reputation.
Just watch because I have run into issues where an aluminum 16" wheels wouldnt fit because the aluminum is thicker than steel which equals less clearance. Not saying youd have that problem, but just something to check.
  #7 (permalink)
Old 07-05-2008, 11:50 AM
I'd planned on using steel wheels. I'm staying away from the traditional white wagon wheels because they tend to only have a 1500lb load rating. That's barely enough to carry the truck! I think i'm going with 16X7 cragar soft-8 (black) and dunlop radial Rover R/T in 225/75-16 front, and 235/85-16 rear. I'm trying to stick with narrow tires for better snow performance, and better gas mileage. Ideally, I want 215/85-16 all around, but is that "too narrow"?
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
