I just bought a 88 f-450 sd that origanally had a 460 in it and now has a 7.3 turbo I can read on the valve cover sticker navistar 7.3.I have a 7.3 idi and a 6.9 idi and this looks completely different.The idi has the injector pump with all the lines going to each injector this has the turbo mounted at the rear of the motor on top and the valve covers have plates attached on the intake side of both valve covers and looks like where the pump is on a idi is covered over with somthing on the turbo motor.Any thoughts of what year or type of motor this is?Anyone ?thats why I want some pics maybe id recognize it.
__________________ 1994 F250 XLT-Reg cab, 4x4, 5 speed, 7.3 IDI Turbo, manual hubs, ATS upgrade, 4" exhaust w/Hooker MaxFlow, custom intake, pyrometer & boost gauge, turned up fuel http://www.cardomain.com/ride/3055099 1987 Thunderbird Turbo Coupe-Lots of fun stuff to make it go fast & take corners http://www.cardomain.com/ride/306349
The turbo IDIs look just like a N/A except with a turbo siting about where the CDR is on the N/A motors. Sounds like you have a Powerstroke to me aswell. If you post pics we could tell you for sure what motor it is.
__________________
94 F350 Crew Cab Long bed 4X4 7.3L IDI Factory Turbo, AKA The Land Yacht. E4OD, 4.10 posi. Getting further from stock with 35 inch BFG alterains on 16 inch micky's, straight pipe, Triple A-piller pod with pyro, boost, modifyed stock oil presure gauge, tc lock light&switch
Here's a picture of the 7.3 IDI factory turbo motor.
__________________
Thats an early powerstroke 94.5-97 with a non waste gated turbo. The guys one forum up can answer all you questions if you have any problems with it.
__________________
