1980/86 F100/350 / 1980/86 Bronco / A Pillar trim covers/panels/mouldings
1980/86 F100/350 & Bronco: These A Pillar trim covers aka panels (Ford calls 'em Windshield Garnish Mouldings) only come "paint to match."
All the following parts are obsolete, an internet search of US Ford dealers parts inventories only turned up a couple of lefts.
E0TZ-1003598-A .. R/S W/Shield Garnish Moulding - without headliner / no Ford dealer has any.
E0TZ-1003599-A .. L/S W/Shield Garnish Moulding - without headliner / Robinson Ford Sales in Calexico CA has one / Maples Ford-Mercury in Warsaw MO has one / Anderson Ford-Mercury in Clinton IL has one.
or
E0TZ-1003598-B .. R/S W/S Garnish Mldg - with headliner / no Ford dealer has any.
E0TZ-1003599-B .. L/S W/S Garnish Mldg - with headliner / Bob Yoak Ford in ST Marys WV has one.
Obsolete parts seller greensalescompany.com has none.
Dennis Carpenter in addition to selling repro parts, also sells NOS (new,old stock) parts.
The NOS site is a PITA to use, because the actual description in the parts catalog needs to be typed in (moulding), then part numbers (in this case 603!!) come up.
I looked thru the entire list = None.
__________________ Bill / Retired Ford Parts Manager ~ 1962/1997
Part Number Research: Trucks: 1928/2002 / Cars: 1928/2003
1963 Galaxie 500XL / 1965 F100 / 2008 Fusion S / 2008 Edge SEL
.....Dennis Carpenter in addition to selling repro parts, also sells NOS (new,old stock) parts.
There is some listed in the regular Ford Truck parts section, not the NOS section, although I can't see if it tells you if there are any in stock. Go to Dennis Carpenter Ford Car, F-100,F-150 pickup and Cushman Restorations Click on the red shopping cart beside 1980-89 Trucks, then click on advanced search. In the top left pull-down list select (Search By) Part# and copy/paste (one per search) each of the part numbers listed by NumberDummy (No need to select category) then click Search.
The whole web ordering from Dennis C is far from ideal although I've stumbled my way thru once. I managed to get the Ford oval for the grille and some weatherstripping after I was told by all the local F100 places that they couldn't be sourced anymore.
BTW, I'd have to rate Summit's ordering system/catalog as about the best i've ever used.
No Ford dealer that I asked around here keeps any of the '80s series F-Truck parts anymore. The size of the F-Truck blue ovals were unique in Oz. No other car/van here had the oval in that size
Didn't know you were in OZ, or that the emblems would be different.
Leave it to Ford to have dozens of blue oval emblems which won't interchange between continents!
