Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1987 - 1996 F150 And Larger F-Series Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 06-28-2008, 07:19 PM
stangman5892 is starting off with a positive reputation.
tire size
what up fellas. Im new to the truck and off road scene but not new to fords. I got a 11 sec mustang also. But anyway heere goes: I have a 93 f250 with the 7.5l. I was wondering what the biggest tire i could get under it without a raising it up? Any help and some pictures would be great.
Thanks
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 06-28-2008, 07:56 PM
gweeds's Avatar
gweeds is gaining momentum as a positive member of FTE.
I put some LT 285 75 16 all terrain tires on my f250, see sig, its a Dana 50 front end. However, they did rub on the front bumper a but, so I put two lock washers on each of the four bolts that connect the bumper to the frame (this spacing it forward about 1/5") and raised it up as high as it would go. Doing that, they don't rub at all, even with the suspension completely maxed out. Gives me enough ground clearance to get over some pretty tricky terrain, nothing crazy, but fun to play around with.
I take it your 93 is a 4x4? There is a difference as far as clearance goes...
If you want to go bigger, consider switching to a Dana 60 front axle, or at least plan on replacing your 44/50 when it breaks if you are doing serious four wheeling. Casual mudding and things of that nature won't kill a TTB, but crazier things can.
Also, you can go a bit larger than the 285 if you notch out the bottom corners of your bumper. However, once you get bigger... You run into wheel-well size issues, and need a lift.
__________________
If you need any computer help/advice, pm me.
-94 f250 XLT 4x4, 7.5L, E4OD
-86 f250 XL 4x2, 6.9L, C6
-95 Nissan Hardbody, 2.4L, 5spd <-- The real work horse!
"Greater love has no one than this, that he lay down his life for his friends" - John 15:13
  #3 (permalink)
Old 06-28-2008, 08:18 PM
thanks alot man. I dont even kow what front axle i have but im sure you know what your talkn about. haha I got the truck cheap and might do a little wheelin just gotta start the learnin process for off road stuff. Its got some bias ply pizza cutters on it know and is not very impressive!!!!!!!!!
  #4 (permalink)
Old 06-28-2008, 08:21 PM
Oh, One more question about those tires. Did you put them on the stock wheels?
  #5 (permalink)
Old 06-28-2008, 10:17 PM
gweeds's Avatar
Yeah, they are stock wheels, 16" rims, 8-lug, which I assume yours are.
__________________
  #6 (permalink)
Old 06-29-2008, 01:17 PM
alright just a few more questions. haha sorry, How much of a lift would i need to get 35's under my truck? Is there any other trucks to get wheels to fit my truck? I dont even know what the bolt pattern is but its hard to find 8 lug wheels. any help would be great! thanks
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
